Trans TC rattle
Trans TC rattle
I was searching and discovered this thread. Need help with a 99 7.3/4r100 4wd with the rattling torque converter.
Background. Sorry for long post.
I bought this truck 10-11 years ago to use as a tow rig for my landscaping company. It has been a great problem free truck, I have done brakes a few times, a water pump, ball joints but no issues with motor/drivetrain.
I don't know the history of the trans before I purchased. Ford didn't have history of it being replaced and even now it still has all the labeling on the case. I would have thought it would have been washed off in a rebuild. Again I don't know. When I bought the truck it shifted nice and crisp, having owned trucks before it made me think it had been rebuilt but this was my first and only 4r100. Other trucks are ZF6 manuals.
Anyway 10 years and 100,000 miles later it still shifts very crisp and fluid, has been changed a couple times, is nice and cherry red. I added a 6.0 cooler, temp gauge and filter. Never see the temp rise and haven't seen much in the filter.
About 25,000 miles ago the TC started to rattle, a known 99 problem. I figured surely the trans would go and I would do a rebuilt from Ford. It keeps going though so being a work truck I have kept running it.
A couple weeks ago the starter just spun and wouldn't engage. I pulled the inspection cover and noticed some missing teeth on flex plate. Got it to start my turning crank bolt a bit to good teeth and the starter caught. Now we are carrying a breaker bar and socket. It has happened a few more times so I need to replace flex plate.
Question is, since I need to pull trans to replace flexplate, should I replace TC (I would like to get rid of the noise)? Some people have said I will be replacing trans in a couple months if I mess with it. They say just spend $3000 on a rebuilt now with a converter. Not trying to be cheap but hate to just dump this trans that is still working great and has served me well.
If I am going to replace the TC, what should I go with? Stock Ford one that is in there has served me well. Replacement from Ford that was specified for this issue is $500. I can get other rebuilt ones from NAPA, Monster trans etc for $400. There are also TCs out there for $1000 or more.
I have replaced many tranmissions and done clutches in many trucks so I am familiar with the steps of removal and installation, just stuck on what I should do.
Thanks.
Thanks.
The rattle in the '99 torque converters is from a problem with a spline inside the converter. The rattle could also be from a cracked flex plate.
If the trans is fine and the flex plate isn't cracked I don't see a reason to not just replace the torque converter. If you have excess money laying around you could rebuild the trans while it's out. I don't think it is necessary if it works well.
Thanks Mark
Flexplate being replaced anyway. I have heard they crack up around where they bolt to the crank. Couldn't see anything when I pulled inspection cover. Noise definitely seemed to be coming from the TC.
I want to replace with a "stock" type TC right? Should I go with the Ford or a reman unit? Anything to avoid?
Any trick to installing the TC on the 4r100. I have always filled them with some fluid before installing and made sure they seated, but as I said never done a 4r100.
Thanks
Thanks
Received 3,108 Likes
on
Interesting. Maybe I should hold off in ordering a TC? Trying to avoid too much downtime as we like to use this truck daily. Also would hate to take it all apart and put it back together and still have noise.
Ford did have a service billeting on noisy TCs and lists a replacement TC for it.
on
depending on the cost of a new converter, it may just be better to have one on hand when taking it apart and putting the new one in.
i have been known to do that on my own vehicles many times, but it is kind of hard to do it with a customers because they never want to "waste money on a not needed part"
Put the trans on end with the bellhousing pointing up. Put the converter on the shaft and rotate it. It will go down several steps. Keep rotating until it is completely below the front face of the bellhousing.
on
Thanks for advice so far. Napa and Advanced Auto both list the same manufacturer reman converter. AA has it for $30 cheaper. No one around me has it in stock so I am going to have them bring it in. Same with flex plate $100 + what 4 gallons gallons ATF? Do the flex plate bolts have to be replaced? Any seals at the converter? I have no leaks around motor / trans right now.
on
