How to keep crank from turning?
A few ideas.
If manual transmission put it in high gear with emergency brake on or wheels blocked.
A stout strap wrench on the damper or pulley can help.
Use strip steel to fabricate a holding tool using two of the pulley bolts on the damper. I have used retired garage door opener arms for this purpose. They already have extra holes and curves which is handy. This is my favorite.
If you pull the cover you may be able to catch and block the starter teeth on the ring gear. There are tools for this or improvise with a helper... just be careful so teeth are not damaged.
A bit risky yet has been done more than once... use an impact gun with capacity roughly equal to the torque required. You really need to know the gun you are using to get enough torque but not so much that something strips or stretches.
Good luck!
Good luck!
DarkStarMedia
05-14-2017 04:50 PM
Harrier
02-05-2012 02:47 PM
Encho
03-02-2010 10:50 PM
hotrod351
03-24-2004 05:47 PM
