Eaton 6052 clutch disengagement lever broken
09-25-2016, 10:51 AM
on
I was trying to manually check my clutch disengagement with a big wrench and it slipped and broke then end off the cast iron clutch disengagement lever. I'll attach pictures. I need any advice ideas etc... This is on a ford C8000. Help please lol.
09-25-2016, 12:50 PM
cast iron is weldable...but there is a specific technique for doing it.......2nd option, that lever could faily easily be re-created out of steel.
09-25-2016, 07:06 PM
What year is the C8000, does it have a hydraulic clutch?
09-26-2016, 07:05 AM
on
It's a 77' and yes it's a hydraulic clutch.
09-26-2016, 09:10 AM
Quote:
Originally Posted by
Allisfordih
It's a ' 77 and yes it's a hydraulic clutch.
Attempting to locate the part you need, I don't see it in this picture of the clutch linkage.
What is an Eaton 6052?
09-26-2016, 09:17 AM
on
Thank you Numberdummy. My truck has a 2 clutch disk set up if that helps?
09-26-2016, 09:20 AM
on
Numberdummy you have decoded this truck in the past for me but here is the warranty plate if that helps for part ID.
09-26-2016, 09:53 AM
Here are pics of two pages of C/CT transmission and related parts applications, which one(s) apply?
I still don't know what an Eaton 6052 is.
09-26-2016, 10:33 AM
Are you sure it's not a Spicer 6052?
09-26-2016, 11:44 AM
Krewat
1977 C8000 ~ Main TRANS code is
B
09-26-2016, 12:08 PM
on
Yes it's a spicer I went and looked. I'm sorry
09-27-2016, 09:09 AM
Allisfordih
I still don't see the part you're asking for, where is it located?
rob1
01-15-2006 12:31 PM
Hardcore4x4er
12-21-2004 01:14 AM
