Cant get turbo bolt off PLZ help!
Hey all,
I am doing some EGR work on my truck. I am to the point where I have one last bolt on my turbo charger that I need to remove. It is the one on the drivers side that requires a swivel.
I am using a 3/8 inch 10mm with swivel on a 12 inch extension. The problem is that the socket just rolls off of the bolt and will not grab it at a square angle so again, it just slips off. I have been working at this one for the past 4 hours.
I figured out the problem. I had trouble with the socket slipping off. The dang bolt was rounded off (From previous owner). so what I did was I got the socket and filled it full of JB weld and stuck it on. If this doesn't do the job then I do not know what to do next... I may be ****ed.
Maybe Cut the head off the bolt... Surely this has happened to someone else.
Are you useing a 6 or 12 point socket? What brand of socket? Sometime getting a better quality tool will make a difference. You might find a Snap On socket at a pawn shop for cheap, if you can't borrow one. 400ish grit sand paper over the bolt head then drive the socket on with a hammer might do it also
