Dies while driving down the road and usually will restart with no problems.Seems to happen more often when it gets hot out. IPR/ICP are good.It took a long time to start once also. I'm leaning toward fuel pump but ?
Let's see those numbers once it's at operating temperature. You should have ICP of580-650 and IPR of 21-23%.
If that IPR was after it was warmed up and 25%, you have a leak, why it's hard to start when warm. AND the 03 year models have a know issue with bad HPOP design.... signs of failing pump are hard starts, loss of power, loss of throttle response.
I'm thinking you have a electrical problem instead. Most likely FICM plugs are loose or its a cam or crank sensor issue.
I would also look at your ICP plug for any oil getting into the plug assy.
My truck idles at 585 and 21% hot. Being you have a swash plate HPOP I am not seeing 25% to be a issue. 21-25% is pretty much in the norm. Ford does substantiate tearing into the HPO system when IPR is at 30% at idle hot.
I really think you have either a sensor going or a FICM plug hanging off the unit.
Push all three FICM plugs in hard and look at the ICP plug closely along with cam and crank sensors.
Thanks for the responses guys. I'll check those plugs tomorrow. The ICP is located under the turbo on '03's correct?
Yes , you may be able ( with gorilla arms) reach it , carefull your reaching in the hot zone., look for oil out the connection side of ICP if none have the engine running and pinch wiggle the connection.
I can't even see the ICP under the turbo more less wiggle it. Anyone have a photo or diagram of the location? I'm really leaning toward the fuel pump because after it dies it takes a bit of cranking to get it started.
