67 bump to 76 dent tie rod swap?
I don't have a 4-wheel drive but I would highly suspect the tie rod stud on a '67 would probably be smaller than one on a '76. There's also the difference in a drum brake front end vs. a disc brake front end and it matters what the GVW of the donor truck is and if it has single piston front calipers or whether it has twin piston front calipers, as to what tie rod is correct since the part numbers do differ.
The simple remedy is likely to just get new steering linkages for a '76 F250 4x4 and install them.
Thanks Ultra.
I am swapping in a 76 disc front end into my 67 highboy. The 67 has replaceable tie rod ends on each end and the 76 has a short end a long end. The 76 tie rod set up that I have is in good shape but didn't know if the older set up would work. Not sure my dual steering stabilizer will work with the 76.
on
If your going to go manual steering like I did it seems the tie rod ends are about the same. But the 76 tie rod is beefier to handle the power slave unit in the middle of it.
The tie rod taper bolt in end should be the same, as the Drag link is the perfect fit being it is 16"3/16 long same as the 76 PA Units so no problem using your stock one.
If your 67 tie rod is better then the 76 then why not use it it's all manual.
Orich
Orich
The reason for the swap is for my dual steering stabilizer. With my 67 set up it has the replaceable ends with the long tube in the middle. The 76 set up has the short coupler on the driver side with a short tie rod and the passenger side has the long tie rod. I'm not sure my dual stabilizer will work with the 76 set up with the coupler about where the clamp goes on.
on
This will be to put my sliding two piece rod to butt up on each inside side to side of the tires.
So you can adjust the tie rod until the front an back side measures the same on the rod you made up as a measuring tool ZERO toe in..
I made up a small OD size of a small straight metal square tube like 3/8" ID and then yet a smaller 1/4" inner metal rod. Or something like a curtain rods each say 3' long.
Once both sides of the tire measurements are even, this is where the front side of your tires is reduced by adjusting the Tie Rod in by 5/32".
Then when front & rear side of tires measurement are the same= (0) Zero toe in.
By adjusting the tie rod by in reducing 5/32th gives your axle the correct toe in. toe in.
If this is to confusing may be go to youtude for a better understanding.
Orich
Do you understand the use of "toe plates"? Google it and view a couple of YT videos. You'll be basically doing the same thing....
I don't have a set of toe plates so I cobbled together my own.... With the tires removed I installed a length of aluminum channel to each face of the rotors, each extending beyond the rotor about six or seven inches.... Then I measured and put marks the same distance in front and behind the axle centerline... The actual measurement is irrelevant.. they just need to be the same and enough to clear the tie rod. Do that to both sides and mark 'em. Using two tape measures, measure the differences between the right and left side, in front of and behind the rotor. Adjust the tie rod to your spec... someone said 5/32-inch of toe-in. I use 1/8-inch toe-in. An extra set of hands to hold the tape measures is helpful.. I usually work alone so taped everything in place.
With tires on, some use marks on the tire tread but I like to be more accurate.
