I'm getting everything put back together and I am just about done but I can't for the life of me figure out where this hose goes to. I marked everything but must have forgotten one. Please help! Lol
I believe I've figured it out, I was looking around to see if there was anything else unplugged so in doing that I found a broken sensor and right next to that there's a fitting for the hose to screw into. So does anyone know if this looks right? And also what sensor that is? Ect sensor?
The gauge sender is behind the power steering pump on the block next to the Timing cover.
No the only thing down there is the oil pressure switch, With the V8s the dash gauge temp sensor is right behind the #5 injector in the lower intake, it's a little single wire thing about the size of a dime with a stud in the top.
