Bump in floor on 84 4x4 e250
That's were the manual transmission shifters came thru the floor with certain 3 & 4 spd transmissions.
Ford didn't make factory 4x4 Econoline vans. All the 4x4 vans were done by different conversion companies. So there wouldn't have been any factory stampings in the floor for transfer case shifters.
Here's some pics of the 3 & 4 spd set ups.
Here's a factory 5spd set up.
And here is an odd duck. This one had a 460 with a 4spd (guessing either a BW T-18 or T-19 ) . This and the 5spd would be similar to what the NP435 would be. I plan on swapping a NP435 into my 89 E350. I think I'm going to make mine a 2 piece dog house. I'm going to cut off the original dog house, where the shifter would come thru, and fabricate a separate shift tower cover. That will make servicing and removing the dog house easier.
The E series from 75+ had it's own windshield, didn't cross with anything else, and so the replacement price was always high as an only fit. Good thing there were a whole lot of E series made
3 speeds were column shifted. The 4 speed OD was floor shifted as pictured in post 9. My '85 used an iron cased transmission with an external shifter similar to that used on the performance 4 speeds in the '60s.
The "SROD" trans may have been used in some years. The turret for the shifter is left and back, and that indentation might have worked for it.
I understand the desire for the MT but those granny 4 speeds..... I think the gaps between gears are worse than the 4 speed OD and it was intolerable.
ymmv, good luck to all.
The grany low transmissions are tough, cheap, easy to find and work great. I like the NP435's better then just about any other manual truck transmission. I've never had any issue with the gear ratio's. And I personally feel in a 3/4 or 1 ton van there isn't a better choice. These are pretty heavy vehicles, not a race car. And if you do any heavy hauling or towing they are hard to beat. I prefer the NP435 over the ZF 5spd and I own both.
