Dumb question about TPMS
I know I'm behind times but this is the first vehicle I've had with TPMS. I was noticing today when I came out of work that my front tires looked a little low. I checked them real quick with my trust stick gauge, they're at 35 and 36 psi. But my dumb question is at what point do they get low enough to trigger the idiot light on the dash? I realize 3 pounds low isn't much but I'll readjust them all to 38 anyway, just because my vehicular OCD won't let me sleep until I do.
So I think it's just the rake of the truck that's putting all the weight on the front tires and making them look lower than what they really are.
It's my understanding and I could be wrong, the TPMS system on the Fords triggers when a tire pressure becomes 20% lower than what is programmed for the vehicle.
You may notice that when you have your tires rotated, the tech walks around the truck with a wand. He's basically retraining the sensors and ensuring that they all are sending a signal.
But talk about Vehicular OCD.......I'm loaded with it.
All of the vents are open the same amount, and level, when my wife moves one (and she will) I have to set it like the others. The volume of the stereo is always at an even number, before I shut the engine off and get out, that steering wheel has to be straight/level.
I have more too
Unk Bob
I gave up on the vents, mostly because I'm always moving them myself. But I do the same thing with the stereo and the steering wheel. I never get out without turning off the AC. If I'm parking the truck for what I know is going to be more than a day or two, I turn the stereo off before shutting the truck off. I've named every vehicle I've ever owned.... Shall I continue?
Thanks for the TPMS answer Bob!
I also have to be seated in the center of the seat, mirror adjusted so the top of the tailgate is on the bottom of the mirror. I also name every vehicle that I've ever had. This 2013 is named "Grizzly" due to the Kodiak color.
For my GPS, the power chord has to be routed a certain way, same thing of I have my cell phone plugged in. And I can't have anything hanging from the rear view mirror that will dangle around. My wife has a blown glass bird looking thing in her Escape. If/when I drive it, I have to take it off of there. It just drives me insane, and I'm not that far away from it already.
Thanks Tim. Be patient while I blindly fumble my way through the 21st century!
I've heard that too. That's why I will turn everything off if I know the truck will be parked for several days to a week or longer. That way those accessories don't take any juice away from my battery while the truck is sitting. If it's going to be really cold overnight during the winter, I'll turn everything off to reduce the strain on the battery. My 2006 truck never failed to start right up, even at -20!
When it gets that cold though, I read about a slow start technique that allows the battery to warm up for a few seconds first before you crank the starter:
First turn on the headlights for a couple seconds.
Then turn the ignition to Accessories position for a few more seconds.
Then finally crank the starter. It starts up a lot easier, with less cranking. Your truck will be a lot happier with you, and your battery will live longer. Once it starts, I keep the stereo off while it warms up, and just crank the defroster to full blast. Then I get my frosty butt back inside the house while the truck warms up!
I'm sure Russ could share a few more tips about cold weather car care.
I park in a garage at night and the truck is a nice 70* when I get in it in the morning. But even if it's outside in super cold weather I've never used my block heater.
I don't get that cold where I'm at -30* actual temp is about rock bottom. Up north they can hit -60* (again actual temp) and you need a little more for those conditions.
Not a bad idea at all, I changed the coolant in my Excursion last winter along with the T-stat. I'm 99% sure it was original coolant from 2002 haha Didn't look terrible though!
My wife's car is a 2005 Mercury with just about 90k on it. Pretty sure it's still on the original coolant also. We just bought it 2 years ago with about 65k, and it was dealer-maintained its whole life so I doubt the Lincoln/Mercury dealer would have suggested that it be changed any sooner than that. I'll do that this fall, then in the spring it's getting a tune-up. I think the trans fluid may have been serviced once before, I'm not sure. I'll have to look at the car-fax again. Regardless I'll take a look at everything before we head off on vacation next week.
I don't have the work space to do any of the work myself until we buy a house with a garage. Renting right now. So we remain good friends with the shop manager at the local Meineke! He's a good guy though, he's fair and honest, and willing to cut anyone a break on the price if it means getting you back a second time. It's hard to find a mechanic that's that fair and honest anymore, so we keep going back. When we do move it will likely be out of the way to come down there for service, but I'll still make the trip. He's already given me a ride home since the service was going to take longer than he estimated. What other shop does that?
2civicrr
6.7L Power Stroke Diesel
12-28-2015 01:11 PM
MadFrank81
08-15-2010 03:14 AM
