Over tightened the tie rod end?
#46
'95 and up is when they changed rotor sizes and caliper style. I don't think this change affected the knuckle...at least not the TRE hole.
A thought is if this thing was part of a fleet, maybe the service shop bored the holes so a TRE more common to the rest of the vehicles could be used?
#47
on
But it isn't seated in the taper of the knuckle the way it is now. The taper of the ball joint stud is only seated on the washer.
#48
I thought your idea was fine Jas, so long as the taper isn't ovaled or otherwise trashed.
If part numbers check out, and the new TRE is the same as he pulled off (measure with a caliper), and if the taper in the knuckle is good, I think he needs to check for TRE body to knuckle clearance. Should be doable by removing the boot, installing TRE, lifting truck by frame, and turning lock to lock. NO washer on the large end of the taper, just on top of the knuckle to get the cotter engaged.
#49
I looked at Ford book(s), Moog, went to Rock Auto, Napa, and O'Reilly's websites and they all say 1994 and down is different than 1995 and up. Now I do not know WHAT the difference is, just that the part numbers are different. It's worth a try, right? What do you have to loose?
#50
The pic in post #13 shows his old one and it didn't fit properly either. I don't know how long he ran it like that, but it worked. Is it correct? No. He needs to figure out what is correct and put it on for his own safety as well as yours and mine. I hope we can help him out.
Since this was a fleet truck (gold mine) there really isn't any way of knowing what has been done to it in the past so it is kind of a shot in the dark, but hey, gotta try something.
#51
#52
#53
#54
The parts guy must have ordered the driver side TRE for a '94 f250 hd and not the passenger right outer like i asked but not a big deal i guess. So i put the new new TRE on her (just got the taper seated snug and this is what it looks like on both sides. (Just for the hell of it i put it in the passenger side knuckle) also, i did not add grease to it to make the boot expand but i think the picture will let you guys know if it is going to work or not. Also bought a digital caliper to see if right knuckle hole was larger than the left knuckle hole.
On left side of truck
#55
#57
#59
Well I guess the parts guy did give me the right part after looking at rockauto. the part number is es2727r. This TRE looked like the same size as the old left outer so I just assumed it was the left outer. Im going to take the inner left and inner right and adjusting sleeves apart and outer left and outer right back to the store and get all new parts for a '94. I hope they fit onto the pitman arm well.
#60
