rebuilding hvac controls?
I have a 95, and the hvac selector switch is hissing pretty bad in "off" and "max a/c" but otherwise works.
I've tried to pop the unit apart in the past and stopped before I broke anything. I freed the 4 outer clips around the outside of the case but it didn't want to budge.
Does anyone have any tips on this? I assume there would be some o-rings or rubber seals that have failed.
I just had mine apart a month ago. And yes, it's fragile!
I only broke one of the tangs, but it didn't hurt it.
Wish I snapped some pictures but I didn't. There is a spring, ball that has to be put back in EXACTLY as it comes out and a small gear. If you dont get it back right, (I didn't....4 times) you have to take it back apart.
Use patience. Also, it may help if it's warmed up some as that may with the clips holding it.
62dump
06-12-2009 12:53 AM
tboss619
12-06-2008 06:18 AM
