rear end question explorer swap
Subscribed! I'm pretty sure I've heard that the offset is normal and nothing to worry about.
Just picked up an Explorer rear end last weekend. Not to side-track the thread, but curious... did you mount under or over the leafs? And what did you do for shock mounts and spring plates? I kept the Explorer plates, but pretty sure the F-1 leafs are narrower (2" vs 2 1/2"?) - not sure if that poses a problem.
There only part about it being AWD is if the rearend you have might actually be a FRONTend. Most 8.8 rearends that I have seen have the ring gear fairly well centered between the hubs which moves the differential over to the right side a few inches. Was the Explorer a 5.0L XLT model...those all have the 3:73 Trac-locs with 31 spine axles.
Thank you... so the drive shaft will just be slightly angled back towards the drivers side and it wont be a problem? If this is the case thats great news !
Haroldmac
20
12-29-2012 12:53 PM
medicpg
08-05-2009 09:28 PM
