No start issues
No start issues
Hey everyone, I'm new to the forum. I've read a lot on here in the last couple of days to try and help sort my issue but I think its time I ask for help. Up until the other day my truck (96 f-250 2wd 7.3 auto 219000 miles) had been running fine. I did an oil change on Friday 9/3/16 then drove over to Hanford Ca from Paso Robles Ca Saturday morning 9/4/16. Got over there parked did what i had to do in the store, about 30 minutes came back out and the truck would turn over but wouldn't fire off. Thought it might be the CPS but couldn't get the stupid bolt out to throw in my spare. After fighting with it for well over an hour i threw in the towel and just tried to start it. This time it fired off, it cranked longer then normal but started so off to Visalia Ca I went. When I got to where i was going I shut it down and tried starting it again but it wouldn't fire. Got the bolt out switched out the CPS and it started up but it did it to me again on the trip home. So i let it sit for over an hour or 2 then it struggled to start but fired off and i got it the rest of the way home. I'm able to work on my own stuff but I don't know where to go with this issue. Only real issue I've had with this truck in 10 years of owning it has been the fuel pump at the back of the engine. Any thoughts or suggestions would be greatly appreciated.
By "allow the truck to crank", do you mean turn the motor over, or mean start? The CPS has nothing to do with the starting system, but a bad CPS will not let the engine run, as it is not telling the ECM when to fire the injectors. A bad CPS can do some funky things.
I had the factory cps take a dump and it would still crank. As far as the other thing you mentioned I don't know what that is. Even though I've had this truck for 10 years I've never really had any issues so I'm still learning. If it was a small block chevy I'd be able to fix it in my sleep.
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Read this as well as the tech folder stickies at the top in the gigantic red bold letters. Report back once you have some idea of what the issue may be.
Looks to be you are having a hard hot start, things to test when it does this is to throw some cold water at the IPR solenoid to cool it of, if it starts you found your problem, just change the IPR sensor. HPO leaks can also be a good indication of hard hot starts such as, injector O rings or IPR O rings, you can get this I rings from riffraffdiesel.com but before shelling any money out invest in a good scan tool compatible with your truck.
on
1 Post
