Smoking Exhaust on One Side
#32
Smoking
hharris8 did the smoke increase when you removed the PCV and plugged it at the hole where the PCV goes in the valve cover. Or another thing you can do is remove and plug the PCV and the breather cap or oil fill on the valve cover because that is were I wanted to know if the smoke increased when you plugged the PCV not in the exhaust pipe. That’s if you have a oil fill on the valve cover.
#33
When I plugged the PCV the smoke increased where the breather should have been. The exhaust did not seem to be different. I have not tried anything else. I have had class overload with essays. Also, I was driving it to work yesterday and while driving 70 on the interstate the treads blew off the tires and made a couple of bald "inner tube" places. Needless to say it is extremely bumpy and even the tires that did not rip are bumpy (maybe they bulged in places or something?) so I am getting tires put on currently and will get the truck back tomorrow afternoon.
#34
#35
My missing post
To the moderator that may have removed my post and the description of my tool and the pitchers that were with the description of the tool. Would you please tell me as to why they were removed and may I get them back with the location as to were they belong. I wanted to lower the price this week end and with it being a three day holiday I may get some sales or at least a guy can hope. But all my post were removed without any notice to me as to why or were the were moved to could the person or persons responsible please respond by returning my post along with my description and the pics.
#36
And I see you have several posts in another of hharris8's threads, and some with pictures on Pages 3 & 10:
https://www.ford-trucks.com/forums/1...aking-oil.html
And I see you have 30-some-odd posts in total scattered on FTE, maybe you can find what you're looking for here:
Ford Truck Enthusiasts Forums - Search Results
#39
They were old and when they let go they were in a garage (all but 1), 2 on a car in the garage and a spare for my car trailer sitting on the trailer tire rack.
It was the tread that let go not a side wall, never seen that happen before just sitting.
Dave ----
#40
#41
Does your breather cap have a hose connecting it to the air cleaner? Or is it a stand-alone cap vented to the atmosphere?
My '84 351W has the hose. The engine is old and tired, yet still keeps plugging away. In theory, fresh air is supposed to be drawn one way through that hose from the air cleaner, and then into the rest of the PCV system. However, because my engine has plenty of blowby, under certain conditions oil fumes blow backwards through that hose into the air cleaner housing. Those oily fumes are then drawn through the air filter and into the carb and burned.
Is that supposed to be like that? Not really, but I think it's fairly common with high mileage engines. Will I do anything about it? Not really, because otherwise it runs fine and I'm too cheap to rebuild the engine to overcome such a minor issue. Occasionally I have to wipe up a little bit of oil that has collected in the air cleaner housing, but that's about it.
If you have just a vented breather cap, it's very likely you're also getting blowby that is escaping to the atmosphere. Unfortunately, the heater/vent intake is at the windshield base, just aft of that big noisy blowby dispenser under the hood. You could try wrapping a white rag around the cap and going for a test drive. Inspect the rag. If oily, then you know the source.
One "fix" for that scenario is to obtain a breather cap with a hose, and connect it to the air cleaner housing. Then your truck will be like mine. Perfect? No. Adequate? Yep.
Also make sure the cowl-to-hood seal is in good condition. This seal helps keep underhood fumes away from the heater/vent intake.
#43
Ultimate Automotive Leak Detector
Ok I have raised the price to what it should sell for since I have put approximately $175.00 into it so far with everything to get it to sale point. I am almost giving it away at the current price of $225.00 per unit. The tool has a 6’ output hose and a 6’ electrical power wires along with an in line fuse for tool protection. I have installed an in line regulator to reduce the output air from the tool to 3/8,s psi as to not hurt anything in any automobile. I put an 8” carbine clip on it so it can hang from the hood spring while you are smoking the car or truck that your working on. There isn’t a leak this tool can’t find large and medium leaks you will see the smoke coming out of the leak location. And for tiny or pin holes such as in a vacuum line you can add automotive dye to 16 ounces of mineral oil and when run through the radiator the power steering the vacuum lines the rear end and axle seals. The transmission lines pan and cooler at the radiator. The braking system and lines. The air conditioning. And anything I may have missed and with the dye all you have to do is use an ultraviolet light to locate most of those tiny leaks because there so tiny you cant even see smoke coming out of the leak location but with the dye at the leak location you just shine the ultra violet light on the leak location and it will show were the dye has seeped out of the leak. So if interested in this tool you can private message me or email me at 1johnnylovsey@gmail.com and we will take care of the transaction with Pay Pal they will take the money and send me a shipping label so I can ship it to the buyer. One last thing I have put a 90 day unlimited warranty on the tool I am so sure of it and its operation that the warranty will make it a no loose investment. If not fully satisfied then send it back for a complete refund.
#44
#45
