Build Time!
#166
#168
#169
That's a good video. I did tighten mine to around 40 psi by feel. That's what it said to do on Guzzles o-ring site. I dabed four corners of the o-ring and then used my 90 pick to push the o-ring in the groove. after that I pulled it in and used motorcraft gray pan sealant under the nut, on the arrows and threads and tighten it up. I then remove the access off around the nut. So far so good. I like what you did, I was just telling every buddy what I did and many others that worked. There several pages on the 99-2003 tech pages that tell what people have done. If it dose leak someday I'll take it up then what I need to do. God bless,
Chet
Chet
#170
I wish you could have made the thrashing Darrin but that wasn't my point in my post. I spent the $300 because the OX starting leaking bad. I would have 'gotten in line' for one of yours.
#171
#172
You know what they say, behind every successful man is a women! lol I don't know about cranking them out but I bet a few guys would like one.
Side note: I have always gotten a kick out of your signature 'wife's car=no upgrades allowed'! Same with my wife's VW diesel bug! She said to leave it alone! But, the real funny thing is one day she comes home telling me that some guy downtown was telling her about a chip that could bah, bah, bah. I just rolled my eyes and left the room.
#173
#174
#175
#176
Well, the turbo came out over the weekend. I just couldn't figure any way to seal that fitting without spending a bunch of money on AN fittings and hoses and having to wait till they arrived. So out she came, resealed the stock fitting, and all back together again. All seems well now.
I also checked on my dipstick adapter and to my discouragement, found a little oil on it. It appeared to just be coming from around the compression fitting which I chalk up to poor prep on my part. So pulled the tube out, cut it to length, and cleaned up the outside with a little sandpaper. I retightened everything as I put it back together, so we will see how it does this go around.
With all that said, the amount of oil that was there after 2 weeks is in itself a major improvement over what it used to be.
#178
