Need help with rear end ID.
08-21-2016, 03:00 PM
on
Bought a 9" rear from an 80's F150.
The axle ID listing on fordification skips from S314 to S316 so it's no surprise I have a S315a. (I tend to wind up with things that aren't listed.)
Id tag says gear ratio is 2L75. Any idea which locker they would have used with a 2.75 ratio ? Power Lock, Trac Lock etc...
08-21-2016, 05:58 PM
Any one able to identify this rear end?
(Sorry for hijacking your thread
08-21-2016, 10:22 PM
The L on the axle tag stands for limited slip.
08-22-2016, 04:41 AM
on
Agreed but which one did they use on the mid 80's F150?
08-22-2016, 02:54 PM
You're thinking of actual lockers by the sounds of it. Limited slip is not the same as a locker.
08-22-2016, 05:20 PM
Quote:
Originally Posted by
OneLostCowboy
The only available factory traction option in these trucks was the Ford trac-loc clutch pack style limited slip diff.
08-22-2016, 08:06 PM
on
Conanski
That's the info I was looking for, thanks Conanski !
Buzz44
06-22-2012 12:13 PM
Big Will
1997 - 2003 F150
03-08-2006 08:37 AM
jenkinsj
22
07-18-2005 10:35 PM
Crazy Canuck
05-18-2003 12:48 PM
bohica
01-13-2001 11:57 PM
