2012 Powerstroke Mods
Hey guys, new member here. I just recently got into Diesel Performance even though I've had Diesel Trucks for years for work. I have a 2012 F-250 that I've had some upgrades done to. I went on advice from a friend that owns a performance shop not too far from me. Like I said I'm really new at this so I'm looking for yalls opinions on what other upgrades I should do now. So far I've got, HS Minimaxx, Borg-Warner Turbo, Exhaust, AFE Intake, Fuel Pump from 2015 Model. Thanks in advance.
From what I have read, there are additional small items needed to install the 2015 turbo on the older trucks. Check these two links for what else might be needed. You might also google for the turbo upgrade also.
2015 garret turbo in a 2011 - Ford Powerstroke Diesel Forum
2015 F350 Turbo ??? - Ford Powerstroke Diesel Forum
Also, some are report that H&S are no long in business. Might want to make sure your tuner company is still around
http://www.powerstroke.org/forum/6-7...-minimaxx.html
Correct. The bottom end of the 6.4/6.0 is a lot stronger than the 6.7. Thanks to stronger connecting rods and a bed plate, they can be turned up pretty high on factory internals.
