6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Battery light, P0625 code, but still charging
Old 08-09-2016, 07:36 AM
mikemass's Avatar
mikemass
mikemass is offline
I clear the code it comes right back. When I test batteries with truck off I get 11.80V.
Engine running with no electronics on = 12.80 - 13.2V
Engine running with a ton of stuff on (AC, headlights, radio) = 12.3V
Revving gets those numbers up somewhat. But it never really maintains a reading above 14V. If I have absolutely no electronics on and really step on it while driving I can briefly get a 14.2 reading. But as soon as I come off the pedal, she's back to the mid 12's.
I cleaned all 4 connections and battery terminals along with a coat of copper based anti-seize on the terminals. I also inspected wire hardness to Alternator. Looks good.
What do I check next before throwing in a new Alternator?
Few things to note. Both Batteries less than a year old. Interstate Battery Brand bought from Costco. Single Alternator - Probably original.
Old 08-09-2016, 09:02 AM
sxrfun's Avatar
sxrfun
sxrfun is offline
A fully charged 12v battery with nothing hooked up should read roughly 12.6 volts...so yours is reading a tad low...however it's prob not the batteries fault......
With the engine running and alternator charging at idle you should get somewhere between 13.7v and 14.7v give or take......With the readings you stated above it looks like your alternator is bad and not producing enough voltage and needs to be replaced.
Now the question is has the faulty alternator ruined the new batteries? It's possible...I'd have them load tested just to be sure and so you won't ruin new alternator.
Old 08-09-2016, 10:10 AM
mikemass's Avatar
mikemass
mikemass is offline
Is the best way to do this is to fully charge them on the bench with a trickle charger and then bring them to Autozone, etc for the load test? I wouldn't mind spending a few bucks on a home load tester. Any recommendations on a decent one that can handle the amps that these batteries put out? Or are they very expensive?
Old 08-11-2016, 09:46 AM
sxrfun's Avatar
sxrfun
sxrfun is offline
Sorry for the delay.....yes your best bet is to take them to someplace like that and have them tested....Charging them up first isn't a bad idea.
Not sure on home load testers.
Old 08-13-2016, 07:26 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
sounds like the batteries are old and need replaced to me.
Verify the connections at the alternator are ok.
Old 08-22-2016, 09:33 AM
mikemass's Avatar
mikemass
mikemass is offline
I installed a new MotorCraft 200 Amp Alternator. This seems to have done the trick. I was going to replace the batteries too, but after installing new alternator and driving around awhile the batteries have fully charged and have passed a load test.
Here's a video I took of the steps I performed to change out the alternator.
Calheader
11-19-2014 02:30 PM
Jake85388
11-21-2012 10:42 AM
stevorino
04-25-2012 06:45 AM
sprint406
37
02-21-2012 06:25 PM
VIKING24
1999 to 2016 Super Duty
02-17-2006 10:12 AM
Quick Reply: Battery light, P0625 code, but still charging
