6.8 3V - vs - 6.2 mpg
To be honest they both are fairly reliable, the V10 is known for reliability but IMHO opinion is a little harder on the gas. The 6.2 seems to be better in MPG department, but really it depends on what your doing with the truck via pulling trailers etc.
While the V10 is a trooper it is a bit of a dinosaur when you compare it to the 6.2. The 6.2 IMHO is a far better ride and better on the gas end of the scale, not to mention the engines haven't really had a lot of issues.
The company I work for we had some 5.4's and still have a few but went to the V10's our V10's are being phased out for the 6.2'S and some 6.7's.
So far the 6.2's have all been good, we have only had one that has a valve issue, other than they have been just normal maintenance items, tires, brakes etc. The v10's are good trucks, the issues we have had is with spark plugs and exhaust studs breaking
Honestly you could do well with either one, but I would have to give the 6.2 the nod if it were my choice. Both can pull a trailer with ease, and both do very well in the maintenance department and being easy on the wallet repair wise.
What ever you decide, I dont think you would mind owning either truck , they are both good trucks
As pocketlint said, both are great motors. Some feel the v10 is a better tow engine because of its lower torque curve, and I'm sure all things equal, it would be, but they aren't equal, the 6.2 has a great 6 speed tranny, vs the v10's 5 speed and that would be the deciding factor for me between 2 identical trucks, Along with the condition of the over all truck. I love my 6.2, and encourage 4.30 gears with them, but 3.73's, which I have, aren't horrible at all. If you come across a great deal on the right v10 truck, I would not walk away from it. The 6.2 will yield slightly better mpg, but not a big difference. I averaged 9.5 towing 8500k 1600 miles.
I don't know anything about the 6.2 but I have an 06 FX4 with the 6.8 3Valve & 4:10 gears. Pretty much the ONLY time I use the truck is for towing our Travel Trailer. 8,700 LBS loaded for travel and I average 6 MPG towing the travel Trailer. I live here in the central valley of Communist California so when I travel I have to climb over some pass be it the Grapevine, Donner Pass, the Cuesta Grade etc. I can't tell you what it gets empty on the freeway or around town since I don't drive it far or long enough to find out. My truck is completely stock down to the rims & tire size.
On average I've seen about 1 mpg better with the 6.2 rig over the 6.8,
However the 3v 6.8 is a much better tow rig, it's a smoother and quieter running motor as compared to the 6.2. And will pull at lower rpms than the 6.2,
Driving the 6.2 unloaded is just fine, and it likes to rev like a sports car.
Guess it really depends what you need the truck for, Gl
