EGR Tube in between Catalytic Convertors Help
Old 08-02-2016, 08:53 AM
WiscoTruckGuy's Avatar
WiscoTruckGuy
WiscoTruckGuy is offline
The 2 into 1 Catalytic Converter (the first one) on my 1994 F150 4.9 2x4 Rattles when im holding the brakes at a stop sign or something so badly!
So today after work i go to battle with the fun job of deleting the first catalytic converter on my truck. (4.9 2x4 E4OD) I can weld well and have all tools and stuff so welding is no problem. The pipe in between the first cat, (one that is a 2 into one) and the second one, has the EGR or whatever tube on it.
What i need help with is how to remove it and install it back on the new pipes ill fab up for my catless exhaust. Can i use hose or would it melt? can i just weld a bung on and clamp it on with a u bolt?
HALP PLEEZ
Old 08-02-2016, 09:26 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
Just cut the tube off, drill a hole in your new pipe and weld it on.
Old 08-30-2016, 11:31 PM
walperstyle's Avatar
walperstyle
walperstyle is offline
And then what do you do about it throwing codes?
Old 08-31-2016, 12:37 AM
Lead Head's Avatar
Lead Head
It won't throw any.
Old 08-31-2016, 06:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,407 Likes on 1,112 Posts
FYI: It is for the air injection system not the EGR.
Mjr. MIZREE
07-16-2019 04:16 PM
fattmann
05-15-2007 03:04 PM
erica
03-13-2004 05:39 PM
1982fordf100
11-14-2003 12:10 AM
spclagenth
Exhaust Systems
02-23-2003 11:37 AM
Quick Reply: EGR Tube in between Catalytic Convertors Help
