2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
F450 Bigger Tires
Old 07-30-2016, 12:04 AM
Azuretruck's Avatar
Azuretruck
Azuretruck is offline
F450 Bigger Tires
Can anyone suggest bigger tires for the F450 on stock rims?
I am also open to bigger rims
Old 07-30-2016, 01:42 AM
LCR's Avatar
LCR
LCR is offline
I know alot of people that run blinged out 22.5s but I think they are all lifted, I think out of necessity.
Old 07-30-2016, 05:09 AM
System's Avatar
System
System is online now
Prolocutor
Received 1,198 Likes on 573 Posts
Because of the commercial truck tires sidewall stiffness that fit on 19.5" wheels, there is no alternate size that is compatible. One option, if you are willing to run aftermarket, American Force will make any other their wheel styles in as direct bolt on. They have to be in 22" size to clear the 450's brake calipers though. They tires you'd run on them would be LT and you would loose a lot of capacity, but it's doable.
Old 07-30-2016, 07:13 AM
Azuretruck's Avatar
Azuretruck
What do you mean by capacity?
American force rims - are they direct bolt on with no modifications??
Also what are LT tires?
Old 07-30-2016, 08:25 AM
EightySecond's Avatar
EightySecond
EightySecond is offline
Are you sure you're ready for an F450. 😄
Old 07-30-2016, 08:29 AM
Rasalas's Avatar
Rasalas
Rasalas is offline
If you are looking for a larger width a problem with replacing duals with bigger tires is the space between the tires. These tires are fairly close together already, especially at the bulge on the bottom when truck is loaded. They cannot touch and require adequate ventilation between them to prevent heat build up.
Old 07-30-2016, 08:32 AM
Rasalas's Avatar
Rasalas
Rasalas is offline
Do you have a need for these modifications or are you just looking to make a "pretty" tricked out ride?
Old 07-30-2016, 08:57 AM
Azuretruck's Avatar
Azuretruck
No need for modifications. I was looking to make the truck look pretty.
Old 07-30-2016, 08:58 AM
Azuretruck's Avatar
Azuretruck
I hope so. I am getting it. We will see how it goes. Learning as we go.
Old 07-30-2016, 09:20 AM
LCR's Avatar
LCR
LCR is offline
What do you plan on towing with it?
Old 07-30-2016, 12:12 PM
Azuretruck's Avatar
Azuretruck
I am thinking of getting a fifth wheel
Old 07-30-2016, 03:10 PM
cyncwby's Avatar
cyncwby
cyncwby is offline
Just to have a nice looking truck and towing a 5th wheel why not get an F350 dually and put 20" tires/wheels on it....readily available for 1/3 the cost of American Force.
Old 07-30-2016, 03:33 PM
troverman's Avatar
troverman
troverman is online now
LT= Light Truck tires, as in what is installed on every Super Duty except the 450. They will be 10 ply / 80psi max, and have less load capacity rating than the 12-ply / 100psi commercial tires which come on the 450.
Basically it's an option to bling the truck out at the expense of capability. I think the 19.5 tires look great as it is.
Old 07-30-2016, 06:11 PM
Azuretruck's Avatar
Azuretruck
Thank you for explaining.
Old 07-30-2016, 07:45 PM
Azuretruck's Avatar
Azuretruck
Can bigger tires be put on stock rims?
Quick Reply: F450 Bigger Tires
