questions about Ibeams
The single piston caliper anchor bracket will be cast integral to the spindle --it does not detatch.
(single piston) Caliper anchor bracket cast as part of the spindle itself.
The twin piston Dayton caliper anchor bracket will be a bolt-on item that attaches to the spindle.
Bolt-on Dayton twin piston caliper anchor bracket.
(visually) easily identifiable between the two caliper mounting types.
Goofy1129, in case you have trouble finding it, here's a direct link:
Started the disc brake conversion - The FORDification.com Forums
The only two parts that absolutely HAVE to come from a donor are the anchor brackets (the circular piece with two 'arms' that the caliper mounts to), and the dust shield. Everything else can be purchased new.
Oh, and the bracket for the proportioning valve if you choose to mount yours on top of the PS gear box like I did.
I would recommend that you purchase new or re-manufactured calipers that are '70 specific, because in 1972, after serial number M80,001 the internals of the calipers and the diameter of the brake line that attaches to the calipers changed. While dentside dual piston calipers will bolt up and work fine on your '70, if you ever need to rebuild the calipers or get a new caliper brake line, you will have to remember to get parts for a dentside caliper. Getting new calipers made for a '70 will make it easier to get the correct replacement parts.
Thanks for the honor of being included in your compilation, HIO!
To the OP, here are a few pics of "early" and "late" F250 Bumpside discs.
Early version. Note the springs, and the cross-bolts guides for the disc pads:
Late version.
Early... note the brake hose goes straight into the caliper.
Late. The brake hose has a short section of hard line and is connected via a banjo bolt.
The assemblage of early Bump disc parts I have acquired for my '71 F250 from the donor:
This was the donor... a former USFWS truck.It also gave up it's custom tuck n roll headliner!! Btw, make sure you record the donor's VIN. You'll think you'll remember but you won't!! Take lots of pictures!
Ford had multiple problems with these calipers, so to verify, the ID number stamped on the caliper must be known to get the correct hoses.
The 2B296 caliper locating pin was notorious for have its threaded portion snap off.
Pic: Look at 2B120. D2TZ-2B120-B was also used 1973/75 as was the caliper locating pin.
There were two different versions used in 1976: D6TZ-2B120-A before serial number A75,001 & D6TZ-2B120-B used from serial number A75,001 & 1977/79.
These calipers were a PITA back then and today...the situation is worse!
Are you dead set on using the period correct brake caliper assemblies on your truck? If not, it looks like the later model F250 front caliper assemblies would be a better way to go, IF the cross bolts are so problematic of snapping off(?).
I can't clearly see the cross bolt's heads in your photos to see if they have hash marks on them or if they are shouldered bolts. If they're grade-2 or grade-5 shouldered bolts, seems it would be easy enough to replace them with Allen head grade-8 shouldered bolts to eliminate any potential problems of the threaded ends from breaking off.
Are they really a problem? Or is it a case of overtightening? The guide pins only serve to guide the pads and tension mount for the anti-rattle springs...(that looks to be the function of them)
I'll see for myself.
