94 f150 4x2 flareside rear filler neck.
Hey guys last night I pulled the rear tank to replace fuel pump. Had it resting on some scrap 2x6s. And suddenly it fell and it ripped the outer hose on the filler neck.
Does anyone know if there is a replacement available thru the diy stores such Az,oreilly,advance.? If not were do i order one from?
It is only the outer hose that attaches to the neck on fuel tank. The inside is good. I trimmed the hose upto the cut and reinstalled. It doesn't reach the bedside to attach it back in the fuel door compartment.
1994 f150 flareside 5.0l aode/4r70w.
I found this number. F2TZ-9034-A
And this link looks promising but the picture deceives me hopefully it is just a reference picture and not the actual item because it is longer than that.
And no, the filler neck IS different from the styleside. Although the outer hose might work.
hnM6zxHtSOum_is02gXrSvmFVqXxcw37bwaAjb78P8HAQ
tuffguy
06-17-2002 02:40 PM
