Tail pipe ideas/pictures?
Just for giggles, this is probably the ultimate in exhaust theory and application IMO....... It's a 180° exhaust headers/system on a Pantera. Commonly referred to as "a bundle of snakes".
It is based on the firing order where the next cylinder pushes the preceding exhaust pulse and then the next cylinder to be ignited pushes out that exhaust pulse, and so forth.... The primary lengths are calculated so they meet at the right time in the sequence... of course it is tuned for a specific RPM range, if not a very narrow band.
Anyhow, I think you get the principle...
If I were a betting man, I would bet you could change the pipe diameter from 2 1/2" to 3" and NOT feel a bit of difference in performance on the street. Maybe on a dyno, but seat of the pants you won't know a thing. There is a big difference between driving it around and flat out at peak RPM.
This is a good watch:
My .02. Too many guys wayyy over think this stuff.
People often assume that a dual 2" system would be equivalent to a single 4". But if you put the 2" pipes inside the 4" pipe, you would have area above and below them that the 2" pipes wouldn't fill. THAT area, is why bigger single pipes flow more Than smaller duals.
Not all backpressure is bad, some is needed to smooth out the pulsing flow caused by the gasses exiting different cylinders at different times. I can't do any flow calculations for you, but there are software packages that will help you figure out what you need.
The X or H crossover pipe is used to balance out both banks of the engine.
Chiefdan
02-27-2019 03:10 PM
