1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Switches
Old 08-02-2016, 01:56 PM
ligito's Avatar
ligito
ligito is offline
Switches
I want to add 3 switches to the area that is occupied by the panel to the left of the red arrow, How does it come out?
Old 08-02-2016, 02:22 PM
kcducttaper's Avatar
kcducttaper
kcducttaper is offline
Best I can figure is a dremel. I've been eyeballing that spot for a while wanting to do the exact same thing with some locker switches and such. If you figure it out, please post up your results!
Old 08-02-2016, 03:55 PM
Derek86's Avatar
Derek86
Derek86 is offline
That looks like a molded piece, not a panel.
Old 08-02-2016, 05:58 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Depending on your year model, that whole section of the dash cover pops right off. After 03-04 somewhere in there, there are screws above the stock radio. Since you no longer have the stock radio in yours, you can likely grip it and rip it to pull that whole piece straight back toward you to make it easier to cut it out and install your switches.
Old 08-02-2016, 08:03 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
That should pop out. That would be where the electronic 4x4 switch goes.
Old 08-02-2016, 11:01 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
I can confirm that on my 1999 2 wheel drive, that small section in question does not pop out and the back is solid without any outline to match the outside. However, like I said before the entire large piece surrounding the radio and gauges does pop out with no screws on mine.
Old 08-03-2016, 01:42 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
find someone with some wood working skills and have him make a wood frame with the opening smaller than the outline you are pointing to......use the wood frame as a guide for a roto tool to cut a nice hole out.....get some nice switches and have the wood guide made to mathc the needed hole...mount the switches on a black piece of plastic...screw the black plastic into the new hole ....mount the balc plastic in the back...nice chrome bolts from the front....simple.
Old 08-03-2016, 07:50 PM
moymurfs's Avatar
moymurfs
moymurfs is offline
On my 06 it pops right out and snaps back in with no problems.
Old 08-04-2016, 12:53 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
You mean that small section pops out or the whole dash trim?
Is your truck 4 wheel drive?
Old 08-04-2016, 06:45 AM
moymurfs's Avatar
moymurfs
moymurfs is offline
Just the square panel. It's a "blank" for those trucks without auto 4x4. It was also an excellent access point to get to my flasher when I went to led turn signals I had to get an electronic flasher. My truck is 4 wheel drive but has manual locking hubs.
Old 08-04-2016, 09:15 AM
kcducttaper
I've got a '99 2wd and I swear that square doesn't come out without some persuasion from a dremel. I figure when I go to install my switched, I'll very carefully measure where my hole needs to be and carefully drill a hole for the switch to mount so it all looks clean. It might pop out on the later models, but it just doesn't pop out on the '99's.
Old 08-05-2016, 08:56 AM
ligito's Avatar
ligito
ligito is offline
I removed the upper dash, the panel does not pop out, it only appears to.
I will use a Carling 3 switch panel to install in that area, like this picture.
The Carling part number is VM3. They also make a single switch panel (VMS),
as well as a 6 switch panel and a modular panel.
Old 08-05-2016, 03:16 PM
moymurfs's Avatar
moymurfs
moymurfs is offline
Tks for the pic. It looks like the carling units will make for a clean looking install.
Old 08-05-2016, 07:58 PM
ligito's Avatar
ligito
ligito is offline
I watched a video that showed how to pop the headlight switch out of the dash.
Wrong year video. It broke the front off the switch and I had to buy a new switch.
I removed the entire dash panel, radio, radio adapter, passenger air bag switch etc.
I reinstalled the headlight switch and airbag switch, so I can drive it enough to get my new shocks installed.
I've had my door panels off several times but still don't know the proper way to put them back in, so the top doesn't jump back out.
Which hooks should be attached first?
Old 08-07-2016, 06:24 PM
ligito's Avatar
ligito
ligito is offline
Bump .
Quick Reply: Switches
