Distributor
Old 07-20-2016, 05:54 PM
maverick600's Avatar
maverick600
maverick600 is offline
Distributor
Has anyone ever used the 1 wire HEI distributors or a Pertronix distributor? I'm changing from EFI to carb and looking to use one of these types but would like some experienced advice first please.
Old 07-24-2016, 09:00 PM
baddad457's Avatar
baddad457
baddad457 is offline
Doing this in what ? Pertronix is easy, just two wires. If you've got a roller cam in the engine, you'll need a steel geared distributor. The so called "one wire" distributors are huge and fuggly on a 302.
Old 07-24-2016, 09:03 PM
maverick600
The one I purchased is from summit racing ready to run. It's a small cap distributor so it doesn't have the big gm cap
Old 07-24-2016, 09:06 PM
baddad457's Avatar
baddad457
Yea, that'll work. The GM type HEI unit is the one that's fuggly and looks completely out of place on a Ford.
Old 07-24-2016, 10:11 PM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
Why not use a Ford Duraspark unit?
Old 07-24-2016, 10:48 PM
maverick600
I have efi now and getting rid of it but I haven't been able to find everything I need for it.
Old 07-25-2016, 08:40 AM
baddad457's Avatar
baddad457
What vehicle is this going in ? If it's something that had an early EFI setup, then a Duraspark unit could be the way to go. That way there could be nothing to rewire, just plug it in and go.
Old 07-25-2016, 08:44 AM
maverick600
If I could find a vehicle that had the wiring harness, module, and distributor than I would have went that way for sure
Old 07-25-2016, 08:48 AM
baddad457's Avatar
baddad457
Where you located on the Gulf Coast ?
Old 07-25-2016, 08:56 AM
maverick600
OS in Miss.
Old 07-25-2016, 08:59 AM
baddad457's Avatar
baddad457
I might have a duraspark harness, I'll look today. Won't have the distributor or the spark box, but you can buy those new at the parts house. If you've got a roller cam, then you'll need an 85 GT Mustang reman distributor for a manual transmission car to get one with the steel gear. You can get these too locally
Old 07-25-2016, 09:03 AM
maverick600
I appreciate the help, let me know but I have already bought the aftermarket one. I haven't pulled the valve covers to see if its a roller or not but I don't think they were in 86 but could be totally wrong.
Old 07-25-2016, 09:07 AM
baddad457's Avatar
baddad457
86 out of what ? roller 302 pushrods are 6.25" long.
Old 07-25-2016, 09:08 AM
maverick600
Its a 86 F150, sorry I thought that was in the original post.
Old 07-25-2016, 09:15 AM
baddad457's Avatar
baddad457
Musta missed that. Sorry. It'll have a roller block with a flat tappet cam then.
Quick Reply: Distributor
