Replacment drums availability
Old 07-17-2016, 10:37 PM
64highboy's Avatar
64highboy
64highboy is offline
Ive got a closed knuckle dana 44 hd. Im in need of replacment drums and wheel cylinders. Does anyone know if there is a source for these in Canada. The previous owner replaced everything but the drums and now its been sitting so long the cylinders are shot to.
Old 07-18-2016, 08:35 AM
6t6merc's Avatar
6t6merc
6t6merc is offline
I'm going to guess you've already tried Lordco without success...
How about RockAuto?
Eric
Old 07-18-2016, 09:38 AM
resonateur's Avatar
resonateur
resonateur is offline
I would suggest Rockauto as well. The prices on the drums for my 66 dana rear were better than any other source and the quality is very good....correct fit as well!
Old 07-18-2016, 09:53 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Front drums and front wheel cylinders are different: 3,000 lb. capacity vs. 3,500 lb. capacity front axle.
Old 07-18-2016, 07:48 PM
64highboy's Avatar
64highboy
I just ordered them though napa they said that the new drums are 12 x 2.5 and thats what mine measured at. $85 each I thought that was pretty cheap.
Old 07-18-2016, 08:02 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
Well done.
Our trucks are now so old that the first question isn't "how much" but "where can I get one of those".
Eric
Old 07-19-2016, 10:30 AM
NumberDummy
No 1964 F250 came with 12" x 2 1/2" drum brakes.
ALL 1955/65 F250 2WD & 1959/72 F250 4WD have 12 1/8" x 2" front/rear drum brakes.
Beginning in 1966, F250 2WD Camper Specials and F250 2WD's with 7500 lbs. GVWR have 12" x 2 1/2" front/rear drum brakes.
If 1968/72 F250 2WD's have optional front disc brakes, the rear drum brakes are 12" x 2 1/2."
Otherwise, all 1966/72 F250 2WD's have 12 1/8" x 2" front/rear drum brakes.
Old 07-19-2016, 06:45 PM
64highboy's Avatar
64highboy
I remeasured and they are 12 1/8 x 2 dont know how missed this. Unfortunately napa only had a listing for one drum so the hd drums must be unavailable.
Old 07-19-2016, 08:00 PM
resonateur's Avatar
resonateur
...check again on Rockauto. I don't own stock in them....but they show several options and I think their price is better than what NAPA gave you.
Old 07-20-2016, 08:49 PM
64highboy's Avatar
64highboy
More info on brake parts needed.
I just got the drivers side apart and noticed there is a small cable that is broken. It looks like it holds the lever back that sits on the adjuster screw. Ive checked rockauto and napa it seems you can buy most of the parts separately and as a kit for this axle. I cant seem to find this little cable separately and it doesnt appear in the picture of the kit.
Old 07-20-2016, 09:02 PM
64highboy's Avatar
64highboy
Old 07-21-2016, 09:15 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Hmmmm. That looks like the cable for the auto-adjusters. Only thing is I can't think of any 4x4 trucks that came stock with the auto-adjusters in 1961-1966. My 1966 2WD truck has them, but neither of my 1966 F250 4x4 trucks have them.
I thought they were only used with the newer designed 12" x 2 1/2" front/rear drum brakes for 1966 2WD, and then not all 2WD.
The part number for the Brake Shoe Adjusting Lever Cable Assembly is
C6TZ-2A178-A
Which, again implies 1966.
I have at least 9 of those NOS in the packages, but they also reproduce them.
1966 Ford Truck Brake Adjusting Cable New C6TZ 2A178 A | eBay
But, notice how it says 1966. I can't imagine this would be correct for your truck unless something has been swapped out.
Good luck!
Chad
Old 07-21-2016, 10:06 AM
NumberDummy
1967 F250 2WD/4WD with 12 1/8" x 2" brakes: First year for self adjusters.
Old 07-21-2016, 10:18 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
That's what I was sort of half remembering. And then it was a different part number for the adjusting cable than 1966, too, so something to keep in mind if a swap was made at some point, I would think.
Old 07-21-2016, 10:31 AM
NumberDummy
C8TZ-2A178-C (replaced C7TZ-2A178-A) .. R & L - Front & Rear Self Adjuster Cable / Obsolete
1967/72 F250 2WD/4WD with 12 1/8" x 2" brakes.
C6TZ-2A178-A .. R & L - Front & Rear Self Adjuster Cable / Obsolete
1966/72 F250 2WD with 12" x 2 1/2" brakes / 1967/72 F350 with 12" x 3" brakes.
Quick Reply: Replacment drums availability
