Battery gauge way low
Received 3,114 Likes
on
I'd tend to think, that if everything is otherwise OK, a stock OEM alternator should do fine. A larger alternator should not be "required", as such.
One aspect that is sometimes overlooked, as mentioned earlier, run a voltage drop test on the individual battery cables and grounding points and alternator hardware. It's simple, quick and easy, and no disconnecting anything. It's based on the fact that electricity likes to take the easy path.
So if we put a voltmeter in parallel with a wire, or connection, while under load, the voltage drop in that circuit will be displayed as a positive voltage on your DVM. Since an alternator and other high current components will be crippled with ohms resistance practically too small to measure, they are always tested under load, for voltage drop.
Just a few hundredths of an ohm resistance anywhere in the circuit will reduce alternator output by 1/3rd. Maybe not enough to notice at idle, but apply any sort of load, and it will not be able to keep up.
Because of this phenomenon I bet a lot of alternators are replaced unnecessarily. It's not that bigger alternators ain't better but it makes more sense to get the performance we already paid for, instead of heating up wire and spending even more on replacement alternators. Worth checking out anyway.
what year truck? on my 88 to 91 trucks, i had to whomp on the top of the dash to get the volt gauge reading properly. all 6 of them were like that.
the needle in the gauge was slightly bent and would rub against the gauge face when it was low voltage or the key was shut off.
What's up everyone. Haven't posted in a while which has meant no issues w the truck lol. Well today the battery gauge continued to go lower and lower. I had the batt, alt and starter checked. The diagnostic tool said the batt need replaced even thought it read like 12.8 volts. What's weird is the batt indicator on the dash continued to go down which to me would indicate a problem with the alt (charging). Battery is from 09 so I'm gonna replace that and see if it helps but is it possible the gauge connection itself is bad or something?
It doesn't take very much corrosion to cause some weird problems. Clean BOTH cables real good and then see what happens.
^Haha that is about what happened! I barely made it home. Another update. The shop said even the new alt is getting quite a load on it after the new alt was put on and said it "probably" would be fine but wasn't sure. He suggested I put it back to stock (clutch fan) and I told him to proceed. That being said, I will have a 6 month old Flex-A-Lite variable controller for sale in the near future and possibly the Taurus electric fan. That may cost more to ship than it's worth though. Let me know if anybody is interested.
Dave_in_desert
02-26-2020 04:40 PM
Brandon
08-17-1999 08:08 AM
