R-12 hose
Old 07-09-2016, 01:06 PM
badaz4570's Avatar
badaz4570
badaz4570 is offline
R-12 hose
My A/C on my 1990 F-250 isn't blowing real cool. A bud gave me a can of R-12 and a hose to install it but the hose has a threaded fitting to hook to the low-pressure side. My truck has snap type fittings like an air hose. I don't know if there is a hose made for R-12 cans to this type of fitting. Anyone? Thanks.
Old 07-09-2016, 01:26 PM
xTHANATOPSISx's Avatar
xTHANATOPSISx
xTHANATOPSISx is offline
If your truck has QD style connections it has likely been converted to r134 and you must not mix other refrigerants.
If you don't understand the differences or why it's an issue, I strongly suggest you have the system serviced by a professional. Most DIYers manage to screw up their A/C systems. In theong term with add-a-can setups pouring tons of extra oils, leak detectors, seal "conditioners" and other garbage. That's on top of not finding underlying issues or wear items as needed.
Really, unless you're a proficient shade-tree, with proper gauges and temp probes, don't start on A/C repairs. It's NOT as easy as auto-zone would have you believe.
Old 07-09-2016, 06:21 PM
sgip2000's Avatar
sgip2000
sgip2000 is offline
Agree. Spent over $1000 on all the proper equipment to do it right.
Crazyotto1
02-27-2014 12:56 AM
fasthauler
07-25-2006 09:12 AM
cigarxtc
Garage & Workshop
04-07-2005 08:02 PM
gtex
03-22-2004 11:02 AM
mtbiker
09-17-2003 07:32 PM
Quick Reply: R-12 hose
