Broken therostat housing bolts
Old 06-29-2016, 11:51 AM
kyle j's Avatar
kyle j
kyle j is offline
Just broke 2 bolts off flush on the therostat housing what's the best way to fix this problem without replacing the water pump and or spending any money I don't have a tap and die set and never used one so is be a little uneasy about it? Thanks Kyle
Old 06-29-2016, 12:00 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
drill them out and use a thread sert but it will cost money
or if you know a tig welder, they might be able to get a washer then a nut welded on to try again
Old 06-29-2016, 12:01 PM
kyle j's Avatar
kyle j
kyle j is offline
What's a thread sert? Is that a tap and die set?
Old 06-29-2016, 01:03 PM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Get a large washer like a fender washer and have the hole the same diameter as the bolt. Weld that sucker on (MIG is fine, no reason for TIG), then weld a large nut on the washer (reason for fender washer). When that cools give a turn, slowly back and forth. This trick works almost every time. I can't remember last time we tried using EZ out.
If you can get the broken bolts out, I recommend using studs. Even if you have to cut the threads off of bolts, those stupid bolts on that housing are a pain. Thread studs into the water pump with a little JB, and let it set up. Then use nuts and lock washers on top, and never worry about bolts sticking in there again.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old 06-29-2016, 01:11 PM
kyle j's Avatar
kyle j
kyle j is offline
Was thinking of trying a a left handed drill bit? Whatcha thing I don't have access to a welder at this time
Old 06-29-2016, 01:30 PM
kyle j's Avatar
kyle j
kyle j is offline
Slight update was able to get 2 bolts out but one is still broken off flush might try left handed drill bits? If you guys think that might work? Lemme know thanks Kyle
Old 06-29-2016, 02:00 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
I thought you could drill these out and use bolts from below, or is it just the 1 front left that you can do that too??
Old 06-29-2016, 02:01 PM
knottyrope's Avatar
knottyrope
bits break and then more issues if the old bolt is in there stuck good
we don't know if you have a welder or not
Old 06-29-2016, 02:47 PM
kyle j's Avatar
kyle j
kyle j is offline
Yea I don't have a welder I'm gonna try using a regular drill bit and slowly drill a hole just a bit then use an extractor bit
Old 06-29-2016, 03:40 PM
knottyrope's Avatar
knottyrope
Acetone and ATF 50 50 mix and put it on there over night to penetrate the threads before you use the EZ OUT
Old 06-29-2016, 03:45 PM
kyle j's Avatar
kyle j
kyle j is offline
To late just broke the tip of the extractor off in the housing guess I'm ****ed now
Old 06-29-2016, 03:47 PM
knottyrope's Avatar
knottyrope
you might get lucky and use a punch to break it up
Old 06-29-2016, 03:49 PM
kyle j's Avatar
kyle j
kyle j is offline
Yea I honestly have no clue what the f**k I'm gonna do now don't have a welder, ac pump bolts won't come out so I have no damn room, no cloolant in the truck no tail lights or bed so I can't get it to a shop, I'm running out of options I might just rtv the **** out of it and throw 2 bolts in and hope for the best at this point I'm loosing my patients
Old 06-29-2016, 03:59 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
Buy another water pump, less down time and you will have a brand new pump.
Old 06-29-2016, 04:07 PM
kyle j's Avatar
kyle j
kyle j is offline
Never done a water pump on these trucks before how hard is it to remove the fan? What else is involved
Quick Reply: Broken therostat housing bolts
