What is the purpose of a riff raff panel replacement
Riffraff Diesel Custom Manual Dash Kit
they've got a picture of 2 gauges on the lower flat in this one... says they are 2" gauges
It also appears that the "standard" gauges from places like glowshift are 2 1/16" diameter, so if that's what everyone is using in their conversions, I'd be willing to bet they'll fit.
Edit: Beat me to the link!
Use a hole saw to make the cut-outs for the gauges. Run it in reverse for a second, then run it forward to cut. I used a 2" hole saw (no one carries a 2-1/16 in stock), and then enlarged the hole with a Dremel sanding barrel. You can get 3 gauges on each flat if you wanted to.
>is there one other than the ability to have more switches and gauges?
What kind of stuff could an excursion owner need 9 switches for? Or 3 for that matter? And gauges? I saw where one x owner put a phone cradle where there normally go two gauges, would a note 5 cradle fit there?
#29
on
Nice. I was at first worried about having the brake controller that low, but I jist kept practicing reaching for it in case of emergency and now it doesnt feel that awkward.
I redid mine a little while ago do clean it up a bit.
I am also worling on changing the color of the entire dash. I like the lighter color of the panel.
