Fan shroud
Notice in the 8146 fan shroud application chart that the only 1957/60 F350 that came with one had DRW (dual rear wheels). No F350 pickups came with DRW's until 1980.
My F600 has one that bolts up with the same radiator mounting holes, but the cut out for the fan is very rough. If not factory, it certainly is a perfect fit to the edges of the core. However, I can't figure out the rough cut center and even some notches in the fan blade where it has hit over the years. With a little clean up of the opening, it will probably make it to the 1/2 ton.
vol1966
04-19-2010 11:31 AM
CUZ'IN PHIL
05-06-2006 10:50 AM
