Delete almost done
#46
Haha ya sorry about that I was going to try to cover my bases somehow before getting caught. I have my parts guy looking into deleting options for me now, thanks
#47
#48
on
Lol all good. I liked the h&s tuning, worked well except wouldn't take adjusting the defueling. 210f is too low when towing, not sure why it was like that. For newer trucks the BD seems to be doing ok. Just finished update, will see if I get the code again. No muffler yet, checking parts store soon if it came in. Needs it.
#49
#51
#52
Does the BD you're using require the tuner connected all the time to stop it from going back to stock tune?
#53
on
Both tuners have memory cards, the tuner doesn't have to be connected, if you unplug it will stay at the last tune entered. The 40428 had firmware issues, would "initializing communication" on startup, but never finish communicating, so I'd go into menu and update firmware again, it would cycle on and off, no effect to running. It would also freeze up when forcing a regen every now and then, lose communication, unplug and start again, it would usually work a second time. A few quirks, but they both offer monitoring and adjust on the fly.
#55
#56
on
I would tend to agree. Once it's downloaded the tuner is just monitoring. No data or input is transferring to the vehicle without your input, to change parameter or power setting. Whatever the last input was, it's stays until reconnected and adjusted.
#58
Any way you could get a video of you driving past someone at a given speed before and after muffler install to get feel for difference in sound
#60
I was too cheap to do my entire exhaust, so I installed a 4" Flo-Pro delete pipe and left the "filter-back" pipe from the factory on mine with the resonator and love the sound. It is actually fairly quiet, but has a nice throaty sound to it until the wastage opens. Then it sounds like a pissed off mountain lion. I kinda like it though. None of the sounds are obnoxious from inside the cab, and similar setups I've heard from outside were not excessively loud either.
