Exhaust Heat riser...
I was wondering what this capped metal vacuum line near the rear of the engine was for, and it took me taking my carb off (for a re-build) to see that it goes down to a heat riser on the left bank of the engine. So it's capped and obviously not functional... my question is: with no vacuum applied, is the default position of the baffle OPEN to allow exhaust to flow, or CLOSED to keep exhaust gases somewhat up in the engine to help with warm-up. There will come a time when this pesky little device will be removed when the exhaust is re-done, but for now I'm wondering if I need to hook it up to a manifold source to make certain the exhaust flows freely.
BTW, it's an 84 F250 with a 302
But actually, I don't drive the truck in the winter time. Maybe some fall weather (temperature wise) but I don't even drive the truck in the rain.
Also, none of the emissions are hooked up anymore but this was actually disconnected before I even got the truck. I'm just wondering if it's playing a small part in my acceleration problem because the exhaust isn't being vented properly.
I'll snap a picture of it an post in the morning. Just got in from work and it's a freaking t-storm out there right now.
Kionga
06-16-2016 02:01 PM
ewemule
08-03-2011 04:03 PM
evin
05-05-2004 08:15 PM
