So my truck is losing oil (about 2 quarts per 650 miles). No visible leaks other then a damp spot on the rear of the passenger side valve cover.
I have checked both sides of the turbo, intake side had a very small film of oil on the boot between the CCV and the turbo. The exhaust side was just soot with no indication of a leaking seal.
Oil cap flip trick for blowby was fine, cap just rattled off. Fuel filter was kind of dirty but the fuel was clean in the bowl
Original owner put the pyro there, I planned on moving it once I got rid of the stock exhaust/DP, I rarely tow (trailer plug has a short) or haul anything more then an atv or mountain bikes.
Picture is misleading, it is the weld. Nothing from the dipstick tube, this truck has never leaked oil. Is there any other indicators that the turbo is on its way out? I am not completely against pulling it and rebuilding it, would give me a reason to do the 1.0 housing and ebvp delete.
Black fuel filter, like yours, is an instant sign of bad injector O-rings. I highly doubt oil is leaving through your turbo, they tend to just dump loads of oil when they do go.
