Locker. Where to begin?
I'm interested in dropping a manual locker (switch on the dash style) in my '99 F-250. I'm pretty new to lockers, but I think all I really need to match up is just the diff size (8.8, I believe) and the diff ratio doesn't really matter as the locker is just going inside the ring gear. I know pneumatics were the way to go for a while, but if electric lockers are a viable option these days for light duty work (driving firewood out of the woods, pulling the boat up the boat ramp, etc a handful of times a year), I think I would prefer to go the electric route. If anyone has some more knowledge to drop, I would appreciate it!
99 f250, 7 lug or 8 lug, that will matter as they are different platforms entirely. From what I gather you are looking for an electronic locker for the rear axle? If for the rear there's no carrier break meaning the differential is good for all ratios. The Dana front axles typically have a break for 3.73& down and 4.10&up. You can also run into thick and thin ring gears so you need to know what you have. You will need to reshim the carrier for backlash during the install.
Do some searching on the Detroit TrueTrac. It's a gear style Posi that would always be engaged for better traction in all conditions and does not use any clutches that could wear out. I'll be going with one very shortly. I'm also nearly ready to pull the trigger on an ox locker for front axle. If you absolutely must have a selectable type locker, have a look at the ox. The cool thing is you can install with just a manual lever with a cable, but they also sell an electric solenoid and air actuator kit if you prefer. They also sell a small emergency tool that allows you to lock the diff manually if your actuator system fails. The tool just screws into the side of the cover.
For your purposes though I think the TrueTrac would be the better choice for rear axle. My buddy has put one in two of his super duty trucks and says it's about as important as putting in fuel. I'll be ordering one very soon
The OX locker is also an awesome product. The ability to do swap between air actuated, cable actuated, or electric actuated is very clever and gives a lot of versatility. And the override tool is pure genius.
Just keep in mind that there will be some decent installation cost with whatever you go with. And with a 99, it would probably be a good idea to get an install kit that includes all bearings and seals for the axle.
Here is an example of the 7 lug 7700 F150.
https://www.ford-trucks.com/forums/1...50-7700-a.html
Thanks for all the good info! I'm still on the fence with locker vs lsd. I've grown up driving lsd pickups and they can definitely be a handful on washboards sometimes. An lsd would be easier and a 'set it and forget it' kind of thing, but I really don't need the extra traction but only a couple times a year.
I have an 8.8 ford axle in my jeep, it has 35s. I installed a electric detroit locker by a performance shop. Got it out to test it going up a 2' rock and i managed to snap the spider gears that came with the locker. I since had an OX air actuated locker installed and have seriously beat it!! It hasn't shown any issues or failed me. Spend a little more up front to eliminate the cost of doing the install twice like I had to. my $.02 is go OX or nothing
I've decided I'm definitely going with selectable locker instead of lsd setup. I did some more proper research today and dang, these can get pricey! An OX is $1,080 just for parts!
Dang man. I was starting to eye this Detroit E-locker literally just 10 minutes before I saw that. You're right though - I don't want to spend twice the time and money because one exploded... Those E-lockers don't seem to have a terribly good reputation, so I may be shelling up the dough to buy an OX.
I'll do a little bit more research to see what's actually on my truck just so I don't get a nasty surprise, but I believe this is the best longevity option for me is the electric version of the OX locker with as short of a cable as I can get (36"), then extend the wires up to the cab.
