2150A - No Distributor Vacuum Port
I ended up doing just that, manifold. The problem I ran into softer doing so was the amount of vacuum advance at idle. Manifold was adding almost 18 degrees of advance. My distributor vacuum advance can is a cheap non-adjustable type. So I found a spot to place a screw that allows me to adjust the amount of movement of the can arm to distributor. Now I'm getting about 10 degrees vacuum advance at idle and it's running much better.
Hi Lee.
46yblock
01-20-2011 04:42 PM
himmelberg
02-12-2005 06:53 AM
rankhankyellow
01-05-2004 10:06 AM
zach007
11-01-2003 10:31 AM
ADSf100
03-21-2003 10:53 AM
