Tailgate Assist Shock
#92
I haven't read through the whole thread, but i have the DeeZee unit on my 04 f350 and since i've had it (over 6 months at least now) it's been great! no issues whatsoever. doesn't bind up or bend, get stuck, nothing.
#93
What are the ramifications of removing the drivers side rubber bumper for the shock? It's there for a reason I guess. I tried moving the tailgate side to side to see if it aided with alignment when you close the gate, but I couldn't get the tailgate to move side to side at all. That's the only requirement keeping me from installing one of these.
Thanks
Thanks
#95
#97
My Super Duty had the built in tailgate step & handle which made it heavy. I had no issues with any part of the tailgate assist. My only dislike was I felt my tailgate dropped faster than it should. It drops slow enough you can let the gate drop with out issue. It's a nice addition to the truck.
#99
Another thing I did not see mentioned is that for me all I need to do is pop the latch with a finger or two and it drops open without using your hand or arm. So basically if you are carrying or holding something with both hands, the tailgate can be opened without putting the item down. Obviously it depends on what you are holding (had to throw this in or someone would say something...LOL).
#100
Installed on on my '06. Rod end popped off the ball on the gate end every time I opened the gate, unless I lowered it slowly and carefully. Was going to call the manufacturer, but before I could it jammed once and snapped the rod. Into the trash it went. Not sure why I had such a bad experience, others seem to have much better luck than I did!
#102
Nope. It just would pop off the ball right at the end of travel. Everything looked lined up right. Then one time when I went to close the tailgate the now-loose rod got jammed somehow and snapped the end off. Might have been a defective piston assembly? I just got tired of screwing with it.
#104
Just to chime in - My tailgate has the step and stripper pole as well. I've had the DeeZee for the better part of a year with no issues. I considered getting another for the passenger side of the gate because it does drop faster than I really want. However, it's not so fast I've felt a need to add a second device. It doesn't make any noise when I let it drop.
BTW, when I installed the DeeZee, I thought I knew more about my truck than some accessory manufacturer located who-knows-where and decided to leave the rubber bumper in place. I could shut the tail gate with it in place, but it was obvious everything didn't fit together very well. I haven't missed that rubber bumper one bit.
#105
