86 F250 dies around a corner
Like the title states, my truck dies now when going around a corner. Doesn't matter what direction, if I go around a corner, it'll die half way through and I lose power steering.
Truck is a stock 460 with the 4180 Holley. It was rebuilt over a year ago. Truck has the electric in tank fuel pumps.
Anyone ever experience anything like this?
I would check them just to make sure they are good but they would have to be vary low to stall out around a corner so it I would not think it to be the cause.
Didn't you just post about tach jumping?
With it runing move the wiring going to the dist. And see what happens.
My guess a bad electric connection some where.
Dave - - - -
Dave - - - -
Dave - - - -
Dave - - - -
Does it instantly shut off as if you had turned the key off? Or does it sputter and die as if it runs out of gas? When it stops, are all the electrical accessories (radio, wiper, heater fan, etc.) operational, or not? What does it take to get it restarted and how long does it take?
Now if you know carbs where do they put the jets? At the bottom of the fuel float bowl.
If the float level was that low it cut the motor off going around corners you would also have issues driving straight starving for fuel.
You also have 2 jets side by side more to the center not the sides.
I would check the float level just to be sure it is OK and yes it can affect the acell pump squirt.
I have been wrong before but I just cant see the float level the cause.
Dave ----
The stock mounting for my coil is horizontal and a few years back I had a coil that leaked out all its oil. Wonder if yours has leaked to the point where you only have a little oil left in the coil and its sloshing around on corners, doing funny things?
And why I said to start moving wires around to see if it happens.
Dave ----
Dave ----
Single or dual tanks? Does fuel level and/or tank selection make any difference? Just thinking out loud, wondering if the problem could somehow be at the tank. Ever lose a gas cap and wonder what happened to the rag you stuffed in the filler neck?
Does the engine die as soon as you enter a corner? Or does it happen a few seconds later? If the latter, that would seem to indicate a fuel supply or carb problem. If it was some weird electrical problem, I'd think that would be more instantaneous.
Any chance of a broken engine mount? If the engine could twist, maybe that stretches or bends a fuel hose just right so it shuts off the fuel flow. Probably not likely, as that would only happen in one direction, not both as you've described.
What about throttle setting? Does this happen in all corners whether you're stepping on the gas or letting off? Or is it only at certain throttle settings?
Is that enough questions yet? What's your favorite color? How far is up? Why do socks fall down yet underwear rides up?
Can you lift the truck way up on one side and duplicate the problem for troubleshooting?
It has dual tanks, but the front tank is out while I wait for the last part to come in and then I can re-install the brand new plastic one. The rear one still works fine, and have never had a problem with it either not putting out enough fuel pressure, or not pumping to the carb. I have however noticed, that lately, I have to sit there and crank on it forever before it starts, so I usually have to throw some gas down the carb to kick it off, which also tells me it is probably a float problem.
It happens about 3/4 of the way through the turn. It couldn't be electrical because there aren't any other issues (other than the tach needle starting to jump now during normal operation) I could either be idling, or accelerating or maintaining speed and the needle bounces about 300-400 rpms.
Truck only has 49k original miles on it. I know mounts can break long before that, especially due to age, but there aren't any other signs that would indicate they're broken.
Throttle setting is at the stock setting. There's a sticker on the core support that mentions what the idle should be set at, and looking at the tach when it's in gear shows it's on the money. I found that if I throw her in neutral, and keep the throttle going or at least rev it 1/2 way through the turn, it stays running.
Black. I'd say when you're high enough to get hurt if you fall. Why do we park in driveways and drive on parkways?
