Time for a new engine need help deciding
Old 06-19-2016, 12:35 PM
ss27gogeta's Avatar
ss27gogeta
ss27gogeta is offline
What did the close ratio zf come in that would be a better transmission for me if I can find a close ratio one I thought they were all the same and heard that they shifted like a dump truck that's why I was not considering on swapping one in but if there is a close ratio one I probably will.
  #47
Old 06-19-2016, 12:42 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
I'm pretty sure the close ratio ZF5 was only available behind Diesels, not the gas trucks?
  #48
Old 06-19-2016, 12:49 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
He's right, the close ratio would be exceptional....but lead is also right, it's a diesel box. Parts are directly interchangeable though, something I'm looking to do myself...buy diesel zf close box, swap innards, sell diesel bell.
  #49
Old 06-19-2016, 01:25 PM
ss27gogeta's Avatar
ss27gogeta
That's a good idea I might try that as well. get the extra strength of a zf. And the gear ratio of an m5od it's a win win in my book.
  #50
Old 06-19-2016, 01:44 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Yes that'd be win win, just not easy to find two zfs at once, also for a good price. Keep your eyes peeled during part collection and build phase.
  #51
Old 06-19-2016, 03:04 PM
Mudsport96's Avatar
Mudsport96
Mudsport96 is online now
True, but if he could find a diesel zf with a busted bell or something it may be cheaper. Dunno just a thought. Then again a stroker with the torque he should be making with that build should also have enough power to leave decently in second.
  #52
Old 06-19-2016, 03:07 PM
ss27gogeta's Avatar
ss27gogeta
And I also plan on re gearing to 4:56 gears at the least I imagine it will move pretty good with thoughs gears
  #53
Old 06-19-2016, 04:22 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Leaving in 2nd isn't an issue even stock, it's the huge rpm drop between shifts with the wide ratio trans that is just a lame setup. 1st is unusable for accel, and rpm drop is gigantic from 2nd to 3rd and 3rd to 4th.
Def a good idea to look for a diesel trans that has a busted case.
  #54
Old 06-19-2016, 04:50 PM
ss27gogeta's Avatar
ss27gogeta
I took a look on the local craigslist and not much but this junk yard I found my engine in has several trucks from this generation so I'll ask them what they have when i go pick my engine up from them next week I'm in no hurry for transmission though I need a good running engine first but I'll keep my eyes open if a good deal comes by I'll probably take it
  #55
Old 06-19-2016, 05:55 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Yep, you got the idea.....parts collection can take a long time but you have to be ready to pull the trigger when something does come up. If it's easy it's not cheap, if it's cheap it's not easy.....being patient and diligent in the search is not easy, but cracking a catalog and ordering a t56 is awfully expensive.
  #56
Old 06-21-2016, 04:00 PM
ss27gogeta's Avatar
ss27gogeta
Picked this up this morning it came out of an 89 f250 she don't look like much but it's a start now I need to tear it down and see what she looks like on the inside gave 200+ 100 for core charge that's half of what every body else was wanting to ship me one
  #57
Old 06-21-2016, 04:47 PM
eduhat's Avatar
eduhat
eduhat is offline
Sweet motor! You're doing what I'm planning on doing. My 94 has MAF on the 302. I've got 33x12.50s with 3.31 gearing which is killing my mileage. I'll be keeping an eye on this thread and will happily give advice if I have any.
  #58
Old 06-21-2016, 05:24 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
If you pick up a lifter tree for hydraulic roller lifters, the machine shop can retrofit that to the block to male it a cheap roller.conversion.
  #59
Old 06-21-2016, 06:10 PM
ss27gogeta's Avatar
ss27gogeta
Whats the advantage of running roller rockers over the flat tappets and I did a little reading if I do this convertion I'll only be able to use Circle base cams and what is a Circle Base Cam
BIGREEN1
04-14-2015 05:43 PM
alz
19
11-01-2006 08:45 AM
alz
10-11-2006 09:33 PM
geokel1014
15
09-27-2004 09:36 PM
fordmudrunner2020
Offroad & 4x4
07-30-2004 12:14 AM
Quick Reply: Time for a new engine need help deciding
