351m to 460 swap?
351m to 460 swap?
got a 1981 f350 2wd with a 351m 4 speed, and i have a built 460 that was pulled out of a 1985 4wd 4 speed, what all would i need for this swap? i know the bellhousings should be the same, and i have the 460 flywheel, i just need to get a new 460 clutch. other than that, engine mounts, what else would i need and how easy would this swap be. i still have the 1985 4wd 4 speed too.
The bellhousings are NOT the same. Only the bolt pattern is, which is fine for a C6.
460's didn't have a manual option until 1983.
And I dont think the 460 clutch is going to fit inside the shallower 351M mechanical release bell.
And in order to use the 460 tranny/bell you need a hydraulic clutch pedal assembly, which doesn't fit pre '83 cabs.
This is why L&L makes a dedicated swap clutch and flywheel.
Make sure you get the radiator and exhaust system from the donor as well.
I've captured several things here: Engine Swaps - ???Gary's Garagemahal. One is the engine stand issue, and another is the flywheel position issue.
And, picking up on Jim's discussion of the linkage, there's another reason you need to go hydraulic - lack of the inner Z-bar pivot for a 460, as shown here: Mechanical Clutch Linkage - ???Gary's Garagemahal. But, while the early cabs weren't drilled for the clutch master, they can be. However, they also should have the brace that is described in that link.
The M bell has the same *bolt pattern* as the 460.
The 460 crank sticks out 1/2" farther and the 460 clutch is taller too
It WILL NOT fit inside the shallower 351M bellhousing.
The 460 bell is hydraulic, not mechanical. So no place for the pivot of the pre-'83 mechanical clutch Z-bar.
Yes the 460 bell will bolt to your existing 2wd gearbox.
ALL truck gearboxes with the "butterfly" pattern will bolt to ALL bellhousings with the "butterfly" pattern, but that doesn't mean the input shaft has the right 'stickout'
And you don't have the hydraulic clutch (pedal, master and slave) needed to use the 460 bell
This has all been known about for over 30 years since the 460 came back in 1983.
The solution is a $$$ L&L flywheel and clutch made for this swap.
You need a '78 or earlier (internal balance) 460 for that.
And a rear sump oil pan with extended pickup.
ETA: That's also a '79 truck, the crossmembers are very different than '80-'86.
Save yourself a lot of headaches, time and risk of damage. Buy the swap mounts, clutch and flywheel.
Bolt it right in.
Use the larger 460 radiator, shroud, front dress and exhaust.
DSII plugs right in, as should the charging harness.
But, you can use the master cylinder from the truck the 460 came from, add a 1983-1986 clutch/brake pedal assembly, and be in business. However, unless you add the firewall brace you have a good chance of then having the firewall crack.
1979 460 with D9TE-AB block casting number is external balance (has a weighted crank spacer).
Ford changed the 460 mid-year 1979. There are no before/from serial numbers or production dates because this was a "running" change.
The block casting number must be known to get the correct harmonic balancer and flywheel (flexplate).
This jazz applies to F150/350 & Econoline only. No 460's in Passenger Cars after 1978, no 460's in F100's after 1976.
Bill,
Yes, it was a running change during the '79 model year
But given the way *many* on this forum understand it, a D9TE block *is* the beginning of production for '79 my engines.
It is MUCH easier to say that '78 and earlier engines were internal, and those *designated* '79 and later are external.
(Although his complete 1985 donor engine will have the obvious counterweights on spacer and flywheel)
