Bosch upgraded 4 hole fuel injectors
Old 06-04-2016, 10:25 AM
eureka16's Avatar
eureka16
eureka16 is offline
I was wondering, if anything, maybe a better response on acceleration, faster start-up. Changing from a single hole injector to a 4 hole injector probably will reduce mpg a little. I thought they were 2 hole injectors.
Old 06-04-2016, 10:29 AM
eureka16's Avatar
eureka16
eureka16 is offline
Interesting how a thread addressing the Bosch remanufactured 4 hole injectors transitioned into a discussion concerning the distributor cap, rotor, contacts, interpretation, etc.
Not being sarcastic, just interesting.
Old 06-04-2016, 09:01 PM
gman97005's Avatar
gman97005
gman97005 is offline
Originally Posted by eureka16
I don't have the part number. I found them on ebay. They are remanufactured, 5 yr. Warranty. $129.99.
Reman Upgrade 4 Hole Bosch Fuel Injectors Ford 1985 1996 Bronco 5 0L 5 8L | eBay
i will use them on my van, good price..
Old 06-04-2016, 09:32 PM
jimandnena's Avatar
jimandnena
jimandnena is offline
Probably won't change any MPG noticeably, eureka, as the computer fires 4 injectors at once, Ford calls it multi-port injection. Once the system warms up enough to go closed loop, the O2 sensor in the exhaust will adjust the fuel mix so the MPG will be the same as before.
Where the extra holes are an advantage is spray pattern and not having a single orifice which could clog but multiple holes. Spray pattern is important if sequential EFI is used by hitting the back of an about to open intake valve.
jim
Old 06-04-2016, 09:41 PM
gman97005's Avatar
gman97005
Batch-fire is the term you're looking for..
Old 06-05-2016, 07:45 AM
jimandnena's Avatar
jimandnena
Yep, that's what everyone calls it except Ford. They have CFI, MFI, EFI, SEFI, and probably some I missed.
https://www.ford-trucks.com/forums/1...l#post16333586
jim
Old 06-05-2016, 04:50 PM
eureka16's Avatar
eureka16
eureka16 is offline
I am going to purchase them. Great price considering everyone else's price. Ebay seller has been around since 2004. 100% positive rating. I have contacted him with some questions. He was very responsive and knowledgeable. Along with the 5yr. Warranty, seems worth a try.
eureka16
06-04-2016 10:11 AM
robbiebrown25
08-15-2013 06:30 AM
coloradotoy
12-04-2009 07:16 PM
GammaDriver
1997 - 2003 F150
01-26-2007 08:35 PM
Fnord
09-20-2002 09:44 PM
Quick Reply: Bosch upgraded 4 hole fuel injectors
