What did you do to your Super Duty today?
#32
I installed rear wheel liners and a smoke black bugshield on my 2016 6.2 xlt yesterday.
Waiting for my custom Cabelas Outfitter Series Seat covers to be finished and shipped out.
This fall (October) right before Hunting Seasons, I will swapping out the 275/70/18 michelins, for some 35's - probably Toyo AT's.
#35
#36
Fixed AC/ESOF prob and door actuators.
Posted this originally on SuperDuty. Should have posted it here. Nubes!?
I was able to fix my AC issue of blowing out defrost vents and ESOF not working thanks to this site. Thanks to Thors Hammer.
Also fixed my door lock actuators all the way around. I didn't replace them. I wrapped resistor in motor with aluminum foil. Thanks to biodieselexcursion, great video.
Great info on this site. My next project will be leaking rear pinion seal.
#37
I did mine recently and just zipped the nut off with an impact, pulled the yoke with a homemade puller, replaced the seal and zipped everything back on. (in a nutshell) I didnt dink with the crush sleeve or the torque specs.
Please note that this is not the correct way to do it at all. For my own reasons I deliberately chose to do it this way based on needing the truck right now and not caring if it grenades on me in the future. I will do a gear swap if I run into problems and will then do everything properly.
#38
Pinion seal
Out of curiosity, how do you plan to tackle this one?
That's why I'm doing a bit of research before I pull the trigger.
#40
Changed the oil, oil filter, and air filter. Was surprised how dirty the air filter was with only 11,400 miles on the truck. Thought I'd show some pics of the muffler delete I did a few weeks ago. Notice the hanger I added behind the resonator. Now notice the gap between the resonator and crossmember. To get that clearance I raised the hanger in front of the resonator. Now it can't rub the crossmember.
Also installed a dual steering stabilizer to control the 37s
#41
-J
#45
Today I ordered 2 sets of JBL GX862 speakers for my '99.
My stockers are all blown to crap, so I went by Best Buy today and listened to all of the ones on display. It was quickly narrowed down to the JBL's and Kickers. The JBL's sounded smoother and had much better control over 1500Hz. Plus I think they may have just a tad more bottom end than the Kickers, so I went ahead and ordered 2 pairs at $100/pair. I'm pretty excited to drop them in and see how it sounds on the stock head unit!
