Curb weight
Old 05-28-2016, 11:47 PM
1978crewcab's Avatar
1978crewcab
1978crewcab is offline
Curb weight
Anyone know where I can get the curb weight for a 1977 F350 crew cab? I have to go pick one up and I need to make sure my trailer can handle it or if I need to rent a bigger trailer. Also it doesn't have the engine or transmission, how much do you think that takes off the total weight?
Old 05-29-2016, 12:13 AM
wyrm73's Avatar
wyrm73
wyrm73 is offline
I know you re looking for a crew cab, but I can tell you my regular cab 4x4 weighed in at around 4850 when I went across the scales at the dump the other day. It gets you in the ball park at least.
Old 05-29-2016, 12:16 AM
1978crewcab
That will work, crew can't be that much bigger. Plus with not having the 460 or C6 in it I should be just fine with a trailer axle rating of 7000lbs. Thank you very much
Old 05-29-2016, 12:14 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
Make sure the wheelbase will fit on your trailer they are long. Will probably be making out a 7k trailer, the crew cabs weigh a bit more, but without the drive train you'll be down a thousand lbs. So should be ok.
Ellen El-Bisi
1999 to 2016 Super Duty
08-29-2017 07:08 PM
Poor'it in'her
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-01-2014 07:55 AM
brandonorban
07-04-2012 11:14 PM
onelugnut
6.4L Power Stroke Diesel
24
06-01-2008 12:08 PM
CruisnPhantom
05-27-2004 03:05 PM
Quick Reply: Curb weight
