2 Questions on Sterlings
You can make any axle fit under anything with enough work. As far as hubs I do believe they interchange but I'm not 100% on that. There's definitely enough room in the hub to have the older patter refilled. What front axle are you using? If it's a older Dana 60 with the standard bolt pattern id suggest using a 14 bolt Chevy for a rear. Pattern will be right, axle is super cheap, strong just hangs down more that a sterling.
infinite-foamies
03-01-2016 10:23 AM
moosebrew
07-06-2010 09:04 PM
