Starter ring gear question -another one
Marauder, what is your bendix tooth count?
Bendix tooth count = 10. Although I feel fairly confident they are the same, I need to verify the tooth count on the flywheel on the 'original' engine. Meanwhile, I have emailed Hagen and the ring gear guy to check their stock of the 2GA-6384.
Someone told me I should just put a SBC in this thing and be done with it...
I have an update to share. Before I realized that it was not the correct part, I had ordered the ring gear from Mac's for the V8. Then I ordered the correct gear from Suehring the ring gear guy. I took a shot of both gears together with the 226 gear on top in both shots. It is obvious that the I.D of the 226 gear is a few thousandths greater than that of the 239 V8 gear. When overlaid you can see the thicker material in the V8 gear. Although I did not put a caliper on them, it appears that the O.D. of both are a match- they lay visually perfect and all teeth line up.
I suppose it's possible that if someone needs a new gear for the 226 when (and if) they are no longer available, the readily available V8 gear I.D could be machined to the correct dimension.
I will be returning the V8 gear to Mac's unless someone here can use it.
#29
#30
1951flatheaddave
03-16-2012 09:39 AM
allenmarv
08-23-2007 02:18 PM
fast77
Bronco II
01-18-2002 06:57 PM
