5.0 swap
5.0 swap
I have a 92 ranger extended cab and 6' bed. 5 speed.4x4. ...engine just lost a cylinder and I figure it's underpowered anyway because I use it for work and have about a thousand pounds in the rear.
I want to put a 92 Ford Bronco 5.0 automatic trans in it. Four-wheel drive as well (both 92 so it should help with the electrical part). Am I going to have any clearance issues? I have a 2" body lift and a 3" suspension lift on my ranger.
Take a measurement from the front of the fan to the rear of the transfer case and compare that to the distance between your radiator and the front of your gas tank. I believe the combination of a C-6 transmission and 2 speed transfer case will exceed the available space and about cut your gas tank in half. 5.0L Explorers used a version of the smaller AOD and used a smaller single speed transfer case version of AWD. Also note the 5.0L Explorers had torsion bar front suspension vs the older Ranger twin I-beam/coil spring suspension. For a work truck, I would probably just rebuild the original 2.9L or 4.0L engine.
on
Ty. Yes obviously I'm a novice.
I see now what you mean by the c4 vs c6. ....if i need to get a c4 I think I'll just get one rebuilt at this point. I'll send the c6 in as the core charge and say **** it. ...the truck will last me another 7 years for 5k worth of improvements. ....hopefully the extended cab allows me to use the c6.
Have you seen this... Ford Ranger V-8 Engine Swap
I've seen that article before and it has some good tips. I'm sure it will save many hours for somebody who is doing the swap. As for that swap, I have a few comments:
"For a V-8 swap using a carburetor, I recommend using an early to mid 1970's Duraspark II ignition." An early 70s Duraspark ignition? Good luck with that one. '74 maybe,,,'75, okay.
"The most popular automatic transmission used in a V8 swap is the Ford C4 3-speed automatic." The most popular? Okay, but that's probably one that I'd stay away from, especially if the owner wants to utilize all that new power.
"Stock carburetors work OK on an off-road truck." Off road, maybe, especially when it's 50 degrees, or colder. But I'd hate to drive a 302 c.i. carbureted engine crammed into a Ranger engine compartment on modern gas in stop-and-go traffic on a hot day. I hate vapor lock...
Okay, I'll stop the bashing of putting a small block into a Ranger now. It's not my truck and I won't be the one putting up with it. I can't believe I'd ever recommend a Chevy, but isn't putting a SBC into an S10 a lot easier?
One again, since this isn't my truck, my opinion means nothing, but I'd just buy a truck that already has more power already installed, especially if this is my work truck and the truck will be DOA for weeks (or more) while this swap is completed.
ANYWAY, good luck with your swap.
If I were you, I'd drop the 5.0 idea, and go for a 4.6 2v. Probably an easier find, probably cheaper, and probably easier to make power with. I am intending to drop a 4.6 4v in my regular cab for racing purposes one day. That is, when the 2.5L 4 cylinder in it gives up, or it reaches a half a million. Whichever comes first.
The 4.6 IMO is a better motor because increased reliability, better power, and better fuel economy. They can also (from what I've heard) be hooked up to a stock ranger 5 spd manual and run that way. Sure, you'll get the group of haters than despise the 2v because of its spark plug issues, and the 3v motors will be hated for their cam phasers.
I don't know where I'm going with this for sure , but I think I'm trying to say, don't look at this as a cheap project. In the race car building world there's a saying, "Cheap, Reliable, Fast. Pick two". Same can be applied to towing, you want strong and reliable trucks you gotta cough up the bucks.
If I were you, I understand a strong connection to cars, (I'd never buy a car I didn't plan on keeping forever. That's why I buy Fords!), look around for an old OBS Ford F250 or F350 7.3L. It'll do everything you're hoping for, and will give you the ability to not subject you favorite ranger to the everyday dangers of daily driving. You never know what's around the corner, you could complete the V8 swap, and hydroplane the next week into on coming traffic and total your poor truck. Think about it.
However, have you grabbed a tape measure and measured exactly how wide a 4.6 engine is? I'm not saying a 4.6 engine couldn't fit into a Ranger, I'm just saying there would be severe challenges. Edit: A quick Google search shows that a few people have done it....
The 4.6 motors, 2v and especially the 4v, are much wider than the old 302.
And they will not bolt up to the Ranger trans. That trans has the German V6 pattern, and 4.6 motors have the Modular pattern bell.
I have an OHV Exploder and for the chassis and brakes it has almost enough power. IMO I'd stick with the 4.0, maybe massage the heads, explore a cam, put some JBA shorties on it and drive it. JMO, ymmv, but you are diving into a deep pool with this swap and you can expect to have your truck out of commission for about double the time you plan.
I just looked up a few "4.6 into a Ranger" threads. Looks like a royal PITA, especially in the exhaust and steering department. I also saw a few threads where the OP simply stopped posting about the progress about 3/4 of the way through, meaning they simply gave up.
