ring gear damage?
It is a 4 speed non synchro box (floor shift). I'm not sure about the clutch as I have never had it out. I also have not researched what was standard on an F3 either.
I'd use a 2x4 or 2x6 across the pan as far back as you can put it without it slipping off. Depending on your exhaust system, you may need to loosen it at the manifold(s) so the engine can tilt forward without cracking the manifold flange. You need to pull the starter and starter plate, too.
Is your truck an F-1? That's an F-2/3 style trans mount. It should have been easy to pull.
No puller needed for the flywheel, just take all the bolts loose, but not out, then pull the flywheel back. If it's stuck a little, pry around the edge with a crowbar, between the flywheel and a solid part of the block. When it's almost off the crank, grab hold of the flywheel and remove the bolts completely. IT'S HEAVY!! Don't let it fall on you or the ground!!
#28
#30
