hpop reservoir loosing prime
Old 05-19-2016, 08:10 AM
rjrandy96's Avatar
rjrandy96
rjrandy96 is offline
I just finished putting the motor back together after repairing a floated valve that broke my rockers arm. The motor is running but after I had it started and ram it a while I shut off and went to start it the next morning it started ran for a few seconds than died. My op gauge read nothi ng so I proceed to think I lost prime. Reprinted it and got it started. Still does the same thing. The entire reservoir drains out into the pain and iv had to drain some oil out from over filling it. I am thinking it's possible I put the lpop in backwards. Because if I had an issue with check valve at the hpop I believe it would start with a Lil more cranking but it's not even close. And the lpop won't prime itself at all no matter how much cranking you do. I would appreciate some help tho. Any thoughts
JT250
22
09-01-2015 08:30 AM
IHateCommieCars
06-20-2015 08:32 PM
nmaine
08-14-2014 07:56 PM
marathonf350
05-13-2013 02:43 PM
davinci69
02-19-2013 08:58 PM
Quick Reply: hpop reservoir loosing prime
