What is the voltage supposed to be at the AC cpmpressor plug?
My AC system was discharged by a leak before I got it, Just checking things out, If I Turn "ON' the system at the dash switch, I get 4.5 Volts at the compressor plug, IS this "normal?"
Thanks.
I don't know... but the A/C isn't going to work without a decent charge, the pressure switch will detect a low charge and will keep the compressor from coming on.
